Thanks guys. Great to meet a few new faces this year too. I don't like this back to work and reality business though...
Besides loosing the power steering belt for 3 stages on day 3 and having the computer go into engine protection twice on day 2 the car ran really well. I've been braking a lot later and harder which means a lot more pad and rotor wear. I really doubt the rotors would have lasted another 100kms of racing. Going to try go from 343mm to 356mm on the front before the next one to see if that helps increase rotor life at all.
Cams were onto the weights this year and got us on the scales twice. With a bit over 1/4 of a tank after Riana we were 1733kg (minimum weight is 1630kg). That's including ~30kg for the spare wheel and a few tools/spares. Not sure where it can come from but I'm going to do everything I can to bring that closer to the minimum next time.
Might be time for a wrap or respray too. Showing quite a few scratches and chips on the front now.
Having issues getting speed/rpm from the data log up so only have two vids for now. Will post more later.
Georgetown, 2nd fastest in EM, 5th outright.
Sideling, Fastest in EM, 6th outright. Audio from our headsets didn't record properly on this one. We fell off pacenotes for a few kms past the long straight 2/3rds of the way in.
  • Like 1
Just watched the Grant Denyer ™ Targa show yesterday. Lots of coverage of the 8 finishers in RWD showroom, not so much everyone else.
They should create a category called "Early Modern" and have 24 interesting cars in it so that they have a better show next year. Afterall, it would be the second largest of their "10 rallies within a rally" after Classic
  • Like 1
  • 4 weeks later...
you thinking about giving it a go? I really enjoy the multi run hillclimb +nav format that Buller used to be.
I assume rules aren't important considering the changes you've made recently (they don't really matter at Mountain motorsports either....or for Targa sometimes it seems....)
No plan to run my "stock" gtr in targa "stock" spec so happy to do these events
So big single turbo, E85, free computers, etc etc etc is "stock" is it? You're allowed all of that and more in Early Modern. So go and have a crack and don't let fear hold you back.
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
