thought i'd join in, just got it for a week now and loving it
not sure which mods to do first but considering
- powdercoated wheels
- autokits rear diffuser (maybe eventually i'll want a front lip and side skirts too for a sportier look)
- grounding kit?
- full exhaust
- air intake
- custom dyno tune
- rear sway bar
- coilovers
Edited by mkn23
  • Like 1
- grounding kit?
- full exhaust
- air intake
- custom dyno tune
- rear sway bar
- coilovers
Choose your exhaust carefully... Beware of the 'drone'.
half asleep parking in a shitty parking spot at work... scraped the pole. yay me haha
First quote is $1120 to fix ... seems pretty OTT. Probably because of munching the quarter panel as well as the front bar. Any recommended crash shops?
Without seeing the damage that sounds about the price to repair both the bar & the quarter panel. If your in Sydney- Ultra Motor Body repair at Homebush West - In my street . I doubt they will be cheaper but their work is always great.
Finally installed the rims that I brought from Japan as check-in luggage haha
My Rays Volk TE37 are lighter but the SSRs are not bad too!
Before & After
Before & After
post-133804-0-20585100-1426599938_thumb.jpg post-133804-0-04329100-1426599966_thumb.jpg
post-133804-0-49400400-1426599909_thumb.jpg post-133804-0-56529300-1426599632_thumb.jpg
SSR GTV03 Matte Black
post-133804-0-36256300-1426599606_thumb.jpg post-133804-0-13606800-1426599660_thumb.jpg
Front 8.5J 18 inch +22 Offset 11.00Kg
Rear 9.5J 18 inch +22 Offset 11.20Kg
post-133804-0-97146800-1426599720_thumb.jpg post-133804-0-67131200-1426599740_thumb.jpg
New rear tyres: Achilles 123S 265/35/18
Edited by allankt86
Before & After
Before & After
Best. Wheels. Period.
  • 1 month later...
After going without a Skyline for almost 5 years due to the death of my old R33 RB25/30 setup Ive finally made the move into a more livable daily setup.... So Here's my recent purchase, 2008 370GT Type S with 32,000kms
Pretty much stock aside from a Fujitsubo Legalis R Axel back exhaust (Didn't know you could only get that section without the whole cat back :unsure: but anyway...)
Have also re-styled my plates to the New NSW Import versions :yes:
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
