wow. your exhaust tips are huge :D
good to know the person behind knows where the battery is located :(
Hehehee yeah :) those tips were on my car when i got it.
love the bowser pic with the car through the hole...top stuff
Yeah not a bad pic, I re-sized them to fit in the thread better
$1.25L i think is high for a fuel made from sugar cane. Doent seem to be cost effective if you are only getting 250km per tank.
I guess with more tuning you could get it down.
we will see, i can run it kinda lean but it starts to miss a little when it goes too lean. I need to play on the dyno and will do 2 tunes, megga lean and normal....
At the end of the day the MAIN reason why i am doing this is because i want to emissions test my car on this stuff, also just to get more exposure out there and learn more about tuning with different fuels etc etc...
I enjoy playing with cars and tuning them for whatever reason so this is also fun !
I have more questions, as always :banana:
In regard to ethanol and rubber corrosion, have you replaced the rubber hoses in your skyline (I assume ther are some)? How hard is this?
Is the corrosion a concern?
And will the ethanol have any side-effects on the engine? I mean the E85 blend itself...
I have been running a 10% ethenol mix in my car (1997 Stagea RB25DET) for about 6 months with no changes to fuel lines etc and no ill effects so far - there is supposed to be corrosion inhibitors included in the fuel. Regarding water absorbtion the Oil Company (Gull in my case) put this forward as a plus saying it will get rid of water from your fuel tank. I haven't suffered any starting problems even on very cold mornings (2 deg C e.g.).
The consensus seems to be that using E10 should not give any problems at all in fact many late model cars we pedal at work say E10 compliant or similar inside the fuel filler flap .
I think replacing rubber fuel lines is a must if you don't want to have problems with slightly older vehicles .
My finding is that not all E10 is the same and that the suff sold by the larger mobs feels like it's low octane rubbish .
The juice my dinosaur Subie lives on is the ultra level E10 meaning supposedly 96 octane - will find out which type of servo it is later .
I think it's possible to have a win in later cars with self learning computers , turbo cars often run rich anyway and the slight leaning should be a good thing . If detonation is down also a bonus .
My Subaru (early 85 RX-T) is not that smart - it doesn't mind 96 E10 and my pocket def doesn't mind 10-15 cents less per liter than name brand 96 ULP .
Cheers A .
yeh i added heaps to the cold start in winter, now its warming up i've got it back to near std settings, except 10+ i think i have that on about 40,
dont stress too much about how much your useing until you've finished playing, mine was bad too, but settled down when my driving went back to normal ( what ever that is ) i've found it uses less if i tune it on the lean side and let the feedback richen it up to lambda, idles smoother too, the feedback is hopeless when it has to take out fuel!!!would pop and fart,
have you noticed how little throttle you need to use at light load? or how much sooner the turbo spools?
anyone worried about how much more they use probabley shouldnt bother, I only use it because i can get it easy ( drive past the servo anyway ) but the main reason is the RON that is it!
Re: problems with ethanol and fuel lines, the story i heard is that it cleans up your fuel system so its worth doing an extra filter change after you've run it for a while.
Re: economy, isnt stochiometric for E85 close to 10? so you'd expect economy to be about 270km from a tank instead of 400 if you're using closed loop control.
okay i made it to Newcastle.. Gauge was sitting at pretty much at full when i left...
I get to the freeway and it was chockas!! so i jump on the old pac all for a bit...
Cruisin on my street tune...
Get to 101km's on the tank so far....
Still a quarter left!!
Get up to 129km's and still going strong!!!
So i decide to lean off the mixture a bit, so i lean her off and she seems to run normal....
Okay then.. lets go some more !
INTERESTING, it seemed to run fine!!! the EGT's were still showing normal numbers...
Okay then.. MORE!!!
Still going strong, but sounds like (out the exaust only) its missing a little.. but cannot feel it in the engine, only sound out the exaust only.
Okay..
.... LEANER.. GIVE ME LESS ETHANOL
19.32 AFR AND STILL CRUISING STRONG.
I did go one more, was running 21 AFR on the freeway and it was popping out the exaust....
By the time i get home... I have done 182km's.....
so how much e85 left in the tank ??
.... ... :P
HALF A TANK LEFT!!! I was running at 14.7 afr (Gasoline converted stoich) for the whole trip except for those little tests and she used half a tank on 183km's....
Soooo.. thats 366km's to a tank!!!! Considering i was getting anywhere from 400 - 450 with BP ultimate I don't think she is doing tooo bad!
I wonder how she will go with the AFR set at 18 or 19 the whole way... more testing needs to be done!
But for now I will be tuning the car in the morning for emissions and worry about the emissions test!
Maybe the e85 economy aint THAT bad after all :D
I dunno man.. im going to make 3 tunes for the test, about stoich (little richer then) then a stoich tune then a really lean tune.. il ask the guys if they will let me go 3 times.. they should let me as they seemed to be interested in helping last time i was there.. im sure if i explain to them what i am doing they might be more interested in the results then I am :P
My car can run on 15.5 AFR on cruise with BP ultimate with no issues.. so I can definatly run the car lean with e85...
Nice!
Do you think you can make it pass emissions with this lean tune ?
When extrapolating the potential range on your car I see you've assumed the bottom half of the tank will give the same range as the top half of the tank i.e. klm's travelled on top half x 2.
Is this a fair assumption...I don't know because I don't own a Skyline. But in all the cars I've ever owned, the bottom half of the tank never gave the same range as the top half?
Just curious.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
