Emptied my catch can today. What came out i can only describe as a thick caramel milkshake!
400mls since the engine was built. Not too bad i think, considering the hard time it gets. The real test will be at Oran Park this weekend, if it doesnt bloody rain!
I don't think I will be able to make it this year. Maybe next year.....
mmmm steak.. I would kill for a decent Aussie BBQ'd 900grm T-bone right now. ohhhhh man.. :dry:
And they work real well with E85 in the US so I imagine here as well .
Now Did I mention the steak knives and to ask for chips with them .
Guilt we need you here for part of the year if possible , cheers A .
Just thought i would mention, a silvia that was tuned at JEM a few day ago cranked out a very impressive 407rwkw on E85 (out of the bowser)
This SR has had alot of engine work and produced the numbers with a hybrid T04Z at 30psi.
In 3 weeks JEM will get their hands on my mates RB25/30 that has been solely built to run on E85.
Hoping to crack the 500rwkw mark :D
Fingers crossed!
Yes Mick's S15 is a power house and we'll be taking it out for a drive on Friday. Did you get that box in Dave?
It's going to be an E85 fest!
Maybe someone should have a chat to old mate at Rozelle next time they go and ask.
It's just so convenient at the pump, having to fill it up everytime with a jiggler would piss me off. I know I sound spoilt to all those interstaters :)
Doesn't stop your car sounding like an F1 car at 8 grand Dave, that's for sure!
mate of mine races a saloon car, the ford v holden sixes etc, they run e85, anyway some of the gun engine guru's have noticed the internals looking a little on the dry side, so they have started putting castor in the fuel, gives it a wild smell that burns your eyes!! was wondering if this would help the fuel pumps last a little longer too.
Edited by 180or200
For the SA boys, the Liberty on tapleys hill rd seaton has E85 at the pump, 99.9c :(
Thats excellent thanks for the heads up :) Could almost use the skyline as a dailly at $1 per litre :thumbsup:
hoppers fuel still smelled normal?
yeah, i noticed on the United website, they have a SA outlet officially listed.
Also heard EVERY Holden model will have a flex-fuel option available by February. Sounds plausible as when i was in the states last month, there were lots of 'flex fuel' and 'E85' badges getting around on a many different models, mainly the chevy's.
Hope it's true as there will HAVE to be more outlets then.
My friends VL was on the dyno today for a tune. Unfortunately the alternator shat itself before the boost could be turned up :P
But on only 12psi made 440rwhp :P
Its going to be an animal!!!!
what heat range spark plugs are you guys running with your ethenol verse pump gas?
over here we run
ngk 7s in 90% of the turbod nissans we tune on 98 pump gas. as it helps aviod detonation
i think from memory we ran ngk 7s in the ethenol mixed cars we tuned also.
although a slightly warmer plug may benifit cold starting with the cooler burning ethenol
although we havn't really don't a lot of playing around with ethenol fuel apart from a couple cars to see what kind of gains you could get out of them
I had 7's and changed to 50% E85 and it was a bitch to start cold, missfired a shitload until fully warmed up and also misfired when first putting foot down after cruising for ages. Tried all sorts of fuel mixtures when cold. Changed to a 6 and all those probs went away.
ok, so i was looking all the way up the inside of my exhaust yesterday ;) (the sun was low enough in they sky that something caught my eye as the inside of the exhaust was not in shadow) and i see a fine layer of red "dust" all along the inside, and quite a ways in. I take it this would be rust? just wondering if i should be concerned at all about this?
car hasn't been driven in a few days and last time i drove it was raining very hard.
cheers for your replys guys
we have just done some more testing e85 on a sr20de+t
specs of it
stock standard S14 sr20de+t(stock cams, head gasket etc)
link g4 ecu and boost control
GTRS turbo
steam pipe manifold
greddy intake manifold,
small 200x300 intercooler.
273kw on 14psi. on a dynapack hub dyno
anybody aware of any Stock long block SR20DE+Ts with more power then that?
making more power and the same torque as his old s13 sr20det on 21psi did on E30
although unfortunatly the small pin hole in the banjo bolt in the turbo got blocked during road testing so its fried the turbo.
so external wastegate to help control boost, and a slightly larger garrett turbo to come soon.
although now were having the issue of lack of water tempature, about 60-70deg. has an 87deg thermostat
what oil grade do you guys use? we currently are using elf 10w40 competion semi sinthetic in it.
although i think we will have to go to a lighter weight oil.
were only just starting to do some of the development for motorsport nz.
im going to be looking at running some e85 in my rb25det, will be interesting to see what kind of gains i can get over my 325kw on 19psi
i just have to sort out my fuel pump and then modify my 440cc subaru injectors to flow double that.
do you guys find that you get ethanol collecting in your catchcan? and your sump level rising and the dipstick being flamable?
i know the ethanol when its with oil thats compatiable with the fuel sits on top of the oil, from what my race fuel supplier has told me.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
