just high flow it. not much more lag than std, and mines pushing 250rwhp at 1bar. thats got the afm maxed, the injectors are prob on the edge too being a red top. strangely the std fuel pump still has some left, unless it was modified in jp. can be done for around 1k or another option is the rb25 unit with similar results but ceramic exh so itll be on the limit
A HKS2530 will give you "Plenty of performance" - around 210-230rwks
Beyond that it cost substantial $$$. What $$$ are you realistically looking at spending on just turbo???
I would love to see what a properly setup HKS2835 with manifold/wastegate/ECU/injectors/AFM would do on an RB20.
A Trust TD06L2-20G-8cm kit with manifold/wastegate is about as big as id go, any bigger and boost response may be compromised a little too much. (Lag in negligible, with boost response bumped up about 1200-1500rpm)
  • 9 years later...
wat's the best turbo for the rb20det, without too much lag, fuel cut etc. and with plenty of performance??????? :burnout:
n e ideas or info wuld b much appreciated
a garrett 2871r would be in the range, a 0.63 rear housing and cranked up to 18-20psi with possibly some E85 to make it come alive even more..
there common on sr20's from what ive seen/read.
How much power are you aiming for?
They have nothing before 4 grand anyway just get a TD06L2 20G 8cm (like $799 from the kando or a billet one from hypergear), a few people have said they have moved from something like a 2530 to something larger and not noticed much difference.
But it depends what you want if you want a whole highmount setup or if you want to keep it as stock looking as possible etc etc.
You mentioned fuel cut. There's no point upgrading the ECU if you're not going to remap or Nistune the ECU at least. I'd go a Garrett GTX3067R with an ATP divided .82 housing on stock manifold modded for external gate.
That would be quite disgusting to drive until 6000. Divided housing then put it on a stock manifold, not really that helpful there
I'm assuming RB20 manifolds are the same as RB25 ones and are divided (other than the 5mm gap which can be welded up)? Why would it be disgusting until 6000? Stock manifold will have better response than aftermarket. I am referring to the new smaller GTX3067R, not a typo of a GTX3076R. The divided .82 housing has better response than an open .63. This setup would be more responsive than a GT-RS/GT2871R with the right tuning and cam gears with a fair bit more top-end potential. Why would this be discusting until 6000? Disgusting on tyres I guess haha. Edited by bradsm87
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
