Hey Marko I was looking at going the Tomei Expreme manifolds but my mate at HKS jumped up and down and said to stick with standards match ported and polished.
He had done alot of their top cars including their Drag 33 and said no reason whatsoever to go with anything else and why change something that works!
that is good hear + they will never warp/crack
  • Replies 286
Throttle body manifold also getting the port/polish treatment
Engine assembly room kept at constant temperature
More match port/polish
Garret hairdryers -5's and Tomei dumps
Hypetune R26 Racing Plenumn fitment
Had a few dramas with this as you can see standard throttle studs too long but all good in the end!
Cams and cam gears getting dialled in
Ok motor back in the car with uprated and modified Nismo Super Coppertwin Racing clutch good for around 580kw
Also view of Tomei dumps and head oil return.
More later..........
What do the guys at HKS think of you using other Brands eg the Tomei Dumps and things like that.
I cant wait to see this car tearing up our tracks :down:
further to that - what opinion do hks have about garrett turbo's? would be good to hear feedback straight from the horses mouth
btw i also run garrett turbo's
Well every time it came down to choice of parts they would say to me .."well HKS make this part but if it was my car I'd recomend using this brand..e.g Tomei etc.
They didnt hold back on advising me what was best to use, absolutely no push to use HKS, only to use what they thought was best for the job !!
I cant wait to see this car tearing up our tracks :)
Love all the pics mate. That is one of the dream set ups I would love to have in my car, one day maybe :O Hopefully we'll see it out and about on the Gold Coast shortly.
Me too fellas, its been a long, long wait ! ..hopefully sometime in August it will all be complied and registered...
Marko they hadnt done many setups using the Garretts . They were surprised to compare the -5's to the Hks 2530's on similar setup engine dyno graphs. Garrett -5's was holding peak power for a little longer than the 2530's.
And hi octane sump extension and hypertune plenum? do they like the aussie stuff?
lookin good tho Mark! not long away now!
Hey mate hows things??
Cars all finished (well this stage) and hopefully not far off from hitting aussies shores.
I'll probably cop a bit of flack here but they definitely were impressed with the Aussie gear and pricing but...there were a few little things in finish quality that would stop them selling in Japan.
Had to do a bit of grinding to get the sump to sit up flush and had a few leaks on the welding but we sorted that all.
The plenumn...they kept stressing about the alloy being to thin and would bulge or deform but once it was on that was thrown out the door. They are quite thinner than Jun plenumn. Also the standard stud mounts were too long and they thought should have been addressed with the plenumn build.
Thing is in Japan, when your a customer and you buy a part form say Jun, Trust, HKS, Tomei, Nismo or any of the big manufacturers, you are buying something that should fit first time and with no mods. Thats the service the japanese expect !!
I think with a few of the small problems addressed the Aussie gear definitely has a right to be in the market with the big guns.
While you are at it ask them about Hypertune plenum vs Nismo?
Mike this will open up a can of worms but we built this engine keeping in mind that it was being built for power and performance but also that at latter stage I might want to go for more grunt. Right now its tuned at bit over a lazy 440kw (600ps) and with right fuel setup and turbo/ s it was built to cope for around 580kw (800+ps)
Anyway the original call was to use Endless plenumn http://www.endless-r.co.jp/pe-ji/orijinaru.htm (scroll down)
but with the Aussie dollar impersonating the peso and talking to a few crew that were using the Hypertune plenumn it made sense and finacially to go with that. Havent looked back as they reckon its super high quality and the response is awesome, the only hiccup was the dramas with mounting.
The Nismo plenumn was never on the drawing board but it would have been easier to use as with the Hypertune we had to cut a hole into the wheel fender for the plenumn piping. (Pics to come)
I think for what your going for Mike, the Nismo will be fine. You got to remember the headwork done to my motor was pretty nuts as it got the full treatment from Naprec and then the HKS GTR meisters went to work on it.
Hope that all makes sense fellas!!
FREAKIN AWESOME BUILD! Really appreciate you sharing your photos with us, but i just have one request, are you able to organise them into an order which is closer to the actual build process? Sorry, i dont mean to complain but it seems as if the photos are all over the place. Maybe its just me!
in reference to the quote below, (my quote button doesnt seem to be working)
"The plenumn...they kept stressing about the alloy being to thin and would bulge or deform but once it was on that was thrown out the door. They are quite thinner than Jun plenumn. Also the standard stud mounts were too long and they thought should have been addressed with the plenumn build."
They are absolutely right. I have seen the one on Godzillas drag car and it has bulged/ballooned way out of shape. This may well be because of the amount of boost that is run. not to say that the hypertune is a bad product but i guess thats probably why jun/endless etc charge what they charge.
Keep the pics coming!
Yeah I know what you mean with the pics but the ones I'm posting up are ones taken and sorted by HKS themselves and theres a few hundred of the buggers so trying to put them in some sort of order. I'm posting them up in the order they were given to me.
The main bulk of previous pics were mine and tried to do them in order of the build. When I get time I'll go through them again and see if I can sort them a bit better.
With the plenum, what I was told normal boost up to 2bar is supposed to be no problems at all.
I cant remember exactly how much but Godzillas is way more than that.
power to the garretts!
Cheers for the reply I really do think the jury is out on aftermarket plenums. Interesting info none the less!
Once again, great build, credit to you.
While Quality is up there at least the Jap stuff fits, Eg the Hypertune Plenum above and the High Octane Sump that leaks.
I would be Pissed if I spent 3k on a plenum and it didnt fit straight on.
i agree - i guess not all aust made bits are at the same caliber as jap stuff
Yes, although the design of the hi octane sump is good, it really is very poorly finished. Casting is VERY rough and like you say a lot of them leaked in the beginning. I suppose attention to detail is what makes Japanese products eye candy to us all. Having said that, not all Japanese products are as well developed as some found in the States and here in Oz.
Edited by AtomicBomberMan
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
