Also with that setup it was going to be an easy 700ps+ and honestly for street setup I think 600ps is plenty.
I personally think its on the bigger turbo setup you really notice the difference. If I decide to throw it on later it will be interesting to see the difference between setups of before and after V-cam.
What I have noticed on cars I have driven that have it is they are smooth. the drivabilaty is great, doesnt feel like you have peformance cams until the lead foot hits and then whammo, that torque hits early !
There are some drags on next weekend that I'm going to unless it rains and there are a few cars going that I know so will try get some vid and pics!
It's never enough power with sticky tyres and especially once you get the hang of it.
It sounds like a good idea to install the V-cam later for comparison but don't you have to reshim the lifters etc etc
It might costs more in the end.
From what you are describing it sounds like one will get more out of the v-cam with an ecu that is capable of dual maps. One map for the v-cam off and one map for the v-cam on. That probably explains why your mate at HKS doesn't think the FC is capable. Most other ECUs in Australia, Autronic or Vipec/G4 or Motec, should be able to do this though.
  • Replies 286
I would love to test it out on my OS rb26/30 + Jun 11.35 setup but fund doesn't permit either and was hoping that elrodeo666 did not change his mind.
Hey Dan check this http://www.osgiken.co.jp/pro_spec/rb30kit-hks.html
Its OS Giken RB30 running V-cam. You can see how much earlier boost comes on. Trade off is you lose a bit of max rpm and top end power, but the grunt comes on early.
We were talking about it today and for eaxample same engine without V-cam they would set limiter at e.g 9000rpm and with V-cam at 8-8500 rpm.
Also max cam is the 264 with 10mm lift!!
OS has a special on these at the moment .. http://www.osgiken.co.jp/topics/rb315kit.html
Hey Marcus and 9krpm,
You gotta give Benno from Racepace two thumbs up for his tuning prowess with the Power FC, technical knowledge and expert craftsmanship.
The combo of HKS 2.8 Step 2; garrett 2860-5; and V Cam Step 1 Type A - Valve timing 90-120 degress, valve lift 8.6mm, duration IN 248 and ex 256 makes for a very fast and super smooth street car. The idle is much quieter and smoother than my NUR engine, probably partly due to the full counterweighted balanced crank and minimal tolerance engine fabrication.
Ben encountered no problems at all with the installation and wiring of the V Cam. I believe the first one to be installed and tuned locally, independently and successfully in Australia. The V Cam behaves pretty like a piggy back module and operates independently of the Power FC, in fact the power FC receives no input signal for the V Cam at all. The V Cam controller is tucked away under the dash - out of sight.
As Marcus says, the V Cam puts much more oomph in the lower rev range. Th butt dyno can certainly feel that. It makes the car feel 'lighter' off the line, and you feel less urge to rev the crap out of the engine
Here's a teaser picture, more to come soon:
Looking forward to more updates Marcus!
Cheers
Matt
Hey Matt
I think the problem some guys are having is they are using V-cam systems that have been tuned in Japan and not straight outta the box new. Pretty much any V-cam controller that has been tuned here in Japan, especially anything done by HKS will have password lock on the software and will need the tuners pin number to change it. From what I've heard and been told here. is no matter what settings you punch in it will revert back to a limp type mode or previous locked settings and you'll need the software writer and codes to change it.
I could be wrong on this but thats coming from the horses mouth so to speak. Sounds like using new outta the box you have had no probs. Now you got me thinking I should get it done after I get back to Oz.
Good to hear you have had success with it. Drivability of the car is impressive hey, like normal until you hit the angry pedal!!
Keep us udated for sure Matt!!
The V-cam fits in well with those cam covers!!
That's awesome news Matt.
If you can, could you show the dyno of vcam off and vcam on?
What rpm does the cam switch over and is it a gradual switch or immediate?
Beside, rpm is there any other factor (eg throttle position, load etc) that affect this transition?
It's very interesting that you are using the v-cam with a small-ish pair of turbo. Most results I've seen are with huge turbo, which make this even more interesting to see :P
Hi,
I shall ask Ben the exact specs of the V Cam setup, as he does not like to tell his client too much technical details. The truth is in how the car drives he says, and not what the specs are!
I will post dyno graph of V Cam with Garrett-5 compared with Stock NUR with N1 turbos.
I have not got a graphical comparison of V Cam on and off reading. I will try and get that comparison graph at my first 1000km service and tune.
Cheers
Matt
Thanks Matt
Thanks for the "expensive carrot" mate.
It would be nice to have some more midrange power but I have to save it for tyres and other bits for the circuit.
The car has missed enough track days for R&D. It's time to get back and have some fun and worry about the midrange power later.
I do hope that you get it though :blush:
Heres some more porting for Beer Baron
Milk crates seen the norm in Japan for head work
Engine finally out
Nismp Copper Twin clutch apart ready for upgrade parts to Competition model rated close to 570 kw
They were working on this freaky little thing yesterday
HKS RACE EVO
Off to the drags tomorrow for the weekend.
Race day sunday so hopefully weathers good and can get some good pics and video.
Suppose to be 100 plus cars going but its Japan and anything can happen
It's good to see your project is progressing well but I cringe every time I see these pics.
elrodeo666 please help your mate and tell him to wear a P1 mask (equivalent to a paper mask at least). The aluminium dust is associated with Alzheimer and early dementia, not to mention other problems associated with metals and silica impurities exposure from the casted head.
Edited by 9krpm
lol, the ol milk crate. same as tets except he uses a wedge of wood instead of the fancy plastic wedge they have at HKS, and he does wear a paper mask. :) the amount of alloy dust that comes out is amazing. lots of material removed and you want none of it in your lungs. tets is covered in it after a good porting session, in his ears etc. d'oh!
  • 2 months later...
Thanks Paul
sent you pm with details...
I'll be updating this thread over next few days, engine is finished and about to finally be installed!!
Well after waiting 2 long months for a small engine hose from Nissan (a#$ewipe,f#$kheads) Japan the part finally arrived and engine is finished and ready to drop in.
A little bit of fabrication being done positioning new inlet pipe for hypertune plenumn first then engine will be put into its new home!!
Seriously Nissan japan are complet A-holes. I was there when the parts manager dropped the hose off and normally in Japan, for making a big company or even little company for that fact, to have to wait so long, old mate would have been bowing and grovelling so low and uttering "we are so sorry" a million times. NOT NISSAN.
Nope it was just sign here and goodbye !! I dunno what it like in Oz but they are pretty shit when it comes to customer service in the spare parts dept! Actually they are useless full stop and pretty arrogant for Japanese.
Anyway engine is done, finally and first tuning should all be done by the time I get back from Nismo festival.
Heres a few pics
New HKS Oil Cooler
RH9 Hi Amp Alternator, ATI Balancer and N1 Water Pump
HKS Adjustable Cam Gear
Engine Rear View
Carbon cam pulley cover and Coil pack cover
Engine view front
Tomei Dumps and Garrat Turbos -5's
Rear View with Modified Hypertune plenumn
Hi Octane big capacity sump
Engine Builder Hiroyuki admiring his work
Engine with HKS Racing Suction kit
Some more pics to come !!!
Hey Marcus, things are looking great,
loving the plenum, ati and dumps. all are in my collection waiting so patiently haha. so annoyed i am not at your stage however
good luck with the tuning! cant wait to see how it all goes!
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
