and it's replies like that will fire him up even more use ya brains the more ya rave on about him the more you feed his ego and power trip better too just ignore him at least on a public furom .
ok, so if i switch over to a standard turbo and still have the braided lines, is it still defectable?
it depends a) if the lines have an ADR rating and b) if the state law permits it. Brake lines are OK if ADR approved, not sure about turbo lines - Call regency and ask them
-D
i know for a fact that braided brake lines are fine but must be adr approved and must carry the adr sticker,etc. But i don't know if you can get adr approved turbo water/oil lines?
Regardless if you had braided or not though,you need the stock turbo.
When calling up regency,ring 3 times,as you'll get different answers each time. They're as useless as service sa.
Word of advice from Officer Neil - "The best Skylines to drive are the standard ones".
I'm not too fussed about Officer Neil coming along to point out and confirm the boost controller to be defected. /start rant But what annoys me was the one that pulled me over for no apparent reason with the intention to defect and manages to only come up with "non standard air filter" anyway. /end rant
cock of shit! they'll still find something if they wanted to
just make it up , thats the aim of the game !!!
probably get defected for something like a supernautical cylinder in the engine -___________________-
Yeah +3. Most Skylines which come out of Japan at a minimal have coilovers and some form of larger exhaust.
Skylines are getting old, so people replace the stock parts.
What a fail of a comment.
Word of advice from Uncle Daniel: "The best cops are the cops who don't defect you for non-defectable items"
What, so it's not okay to drive a modified Skyline but it IS okay to drive a WRX with 22" chrome rims on it with LCD's on the firewall?
Why doesn't he start targetting other forms of modified cars... like Lancers with Evo bodykits and Canons.
Mate trust me when i say they look at wrx's! Mine is my daily and its still on standard rims slightly lowered and a cannon muffler and i get followed flat out all the time so its not just skyline's they look at!
So maybe everyone should avoid the Arndale area in general. I know I drove through there yesterday and I saw about 5 cops on the same road, thankfully I was behind some cars so they didn't see me at all I don't think.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
