does anyone have any std GTR injectors that i could borrow?
my car got defected and i'm running 1000cc injectors and E85, am just wondering whether i'd need to change the injectors out and get it through on a PULP std tune or whether i'd be able to leave the bigger ones in and leave the car on E85?
all the fuel lines are stock or at least look std. its all done with propper tubing.
Depends do the injectors look stock or do you have a custom fuel rail that makes it obvious?
wont it affect emissions or something
They dont check idle emissions, if they suspect something they will request you get an application to modify vehicle and specify it as a condition on there.
You will be fine, if your injection system looks stock, stock ECU then you will be fine.
what are peoples thoughts on going through regency with R33 LCAs on a 32, FMIC with a hole cut under battery tray, z32, gt3076, nistuned rb20 ecu on a rb25.... ?
gonna ring regency monday aswell...
Z32 AN GT3076 will get picked on that's about all sorry to hear you got defected
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
