If You Could... Porsche Or Gtr
For those who have never been to Tokyo, this is defintely a city for 911's. The ones who can afford them obsolutely love them and you can pretty much find them all day long.
A Porsche guy came into our office yesterday to pick up my bosses car for its 1st service informed us of something interesting. At his dealership alone, 5 of his customers traded in their 911 GT2's and GT3's for the new GTR. :/
After a few months, they all switched back. :/ When asked why, they said after you the thrill of the straightline accelaration and hype goes out, they prefer the Porsche which I can understand. He also mentioned that the new PDK transmissions are not that good.
Just thought I would share this with you guys.
Edited by N/A®
https://www.sau.com.au/forums/topic/249366-if-you-could-porsche-or-gtr/
  • Replies 109
R35 GTR....It's faster and tougher without the wank factor......not only that there a lot of change to spend of even more go faster bit's. :/
Edited by Jetwreck
Im sure thats what the Porsche owners are saying as well. Personally I have owned many Nissan models including GTR although not the 35 and would probably go 911 as well. I mean just look at that front end and the built is so much more better compared to the Nissan.
Reliability is the key. I think we all know that 911’s can take redline punishment day after day and year after year and they just laugh right back at you! The question is can the GT-R handle this same kind of punishment and perform just as well? Only time will tell!
After a few months, they all switched back. :D When asked why, they said after you the thrill of the straightline accelaration and hype goes out, they prefer the Porsche which I can understand.
well obviously they prefer the porsche... otherwise they wouldnt go back to it. But, why do they prefer the porsche?
:D
Because Ive owned many Nissans including GTR, although not the 35 which I contemplated buying before getting my 6 series. Also I have easy access to the 35 here in Japan and my boss owns a Porsche.
The biggest 2 difference for me is the quality and at the end of the day knowing that its only a Nissan which anyone can buy. But thats is after living in Japan for 4 years. Unlike when I was in Australia, I see a GTR now and I dont even take much notice honestly. :D
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
