Interestingly, I've found the GTX cards to be understated in almost all graphics/games benchmark tests. Either matching them with shitty hardware or AMD been shaking hands with people!
Recent testing in the office shows otherwise.
290 / 290X cards smash their NV equivalents in all of the benchmarks - the 290X we tested was definitely faster than a 780ti. As for the cooling issue, we used a Gelid aftermarket cooler that dropped temps in Uber mode by 20 degrees.
they might run hotter, but at a significantly lower price, they're a pretty compelling buy, especially for >1080 resolutions. This is from a place where we've all always been all Nvidia as well
Problem is you need the aftermarket cooler, you can OC the stock cooled reference TI like a mofo
Either way both great cards, but not a fan of ATI drivers really. Oh and seen some evidence that shows mantle to be worst looking in game for dat dere 10% or what ever it is in bf4 lol
Benchmarks aren't everything though, quantity over quality sometimes. An example being that BF4 is made for ATI cards, so similar specs and benchmarks will still favour the ATI in an FPS contest. Bitcoin mining being another. But not all rendering is equal, and drivers/support/control/OC are very good in the NV house. 290 seems like very good value all round.
Went & bought a netgear 4 bay Nas unit along with 3x WD 3TB red drives to off load all my animes/movies/TVshows to that instead.
One of my old 2TB WD green is dying (WD20EARS) & luckily I had most of the stuff on there backed up to a external drive before hand, seems like all the drives that have shown signs of dying were WD greens (2 so far), with the exception of 2 segates that were DOA... the oldest hard drive, an old samsung 7200rpm unit (that I use as my main game install drive besides the SSD boot drive) I salvaged from my old PC bulit is still working flawless.
Random people have being telling me leaving bit torrent running wears hard drives out faster, Is there any truth to that or complete BS? That dying WD green was one of the main drives that I had BT constantly running most of the time, coincidence?
Edited by Mayuri Krab
Yep seen enough failures of Greens on various RAIDS - the speculation is that the drive's powerdown energy saving features create havoc in the array. I'd be using regular drives.
If you're paranoid about drive wear, use a Red or a Black / Blue as a scratch disk for your torrents, then have them automatically move to a Green on completion.
My standalone Greens have been going for 3-5 years respectively, no complaints, make sure they get adequate airflow and aren't subject to vibration
planning on doing some shopping next month, am tossing up between EVGA GTX760 (because i like EVGA support + tools and ive only ever had nvidia cards) OR sapphire R9 280X (got some good wraps. would have preferred a toxic, but extra $200 for some cooling...)
nvidia has better base clock speeds but more pricey... i would prefer SLI over cross-fire mainly due to chipset availability in next 12 months.
http://www.scorptec.com.au/product/Graphics_Cards/NVIDIA/51149-04G-P4-3768-KR
http://www.scorptec.com.au/product/Graphics_Cards/AMD/51789-SA-R9280X-3GD5-OC
also thinking of picking up another SSD
http://www.scorptec.com.au/product/Hard_Drives_&_SSDs/Solid_State_(SSD)/48725-CSSD-F128GBGS-BK
and desperately need new keyboard
http://www.scorptec.com.au/product/Keyboards/Mechanical/50630-DK2108S-AUSALT
I'd be looking at a old 680, or 770 GTX (considering they are the same card, and better than the 760 if you gonna spend $400)
e.g http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1486&products_id=23601
also the samsung SSDs are awesome
I got the 280X (and after a few hours of trying to get drivers to work) seems pretty good with Rome 2. runs nice and cool.
Samsung and Corsair are same thing basically, ended up with Corsair 128gb and meh: its a hard drive.
ah yeah thats right forgot you were having driver problems lol
and yep thats it, my ssd isn't the best anymore but in terms of real world performance meh not going to notice any difference if I got the latest and greatest one.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
