I use to have a Hybrid CrossfireX setup on my PC a while ago (Radeon 5770 + GeForce GT220). The Radeon for graphics and the GT220 for dedicated PhysX...It wasn't too bad but It could be better with a better nvidia card and a more powerful PSU (I've only got 620W in mine currently)
I know that the 6970 has the Lucid Hydra Chip onboard so you can run this card and virturally any other card (AMD or nVidia) together. There is some teething problems drivers wise and scaling issues..and the some of there testing I have seen doesn't look too good but you have to remember this is very new and raw so it will take some refinement
Edited by BigDirtyJase
thats where the extra money from a 2500k to a 2600k is
still a good score but not quite as fast, are you still running 4.3ghz
Just put on my cpu cooler and o/c'ed to 4.7
Super PI dropped to 8.03s
3Dmark11 was 5650, so got a little improvement :)
3DMark Results
Apparently my PC is now comparable to similiar systems, heh.
Edited by SoFreshSoClean
awesome what cooler was that again
i have been toying with the idea of getting this
http://www.mwave.com.au/sku-18030281-Antec_KUHLER_H2O_920_CPU_Cooler_Compatible_with_Intel_Sockets_LGA_1366_1155_1156
EDIT ^^ those links are gay and you have to click it twice, open page shut page open page
EDIT just saw in the other thread a Thermalright TRUE 120 cooler
Wow, I gotta get me a second GFX card :)
not sure if you're being sarcastic...
will probably lean on the cards a bit more, but given that I'm sitting on the edge of PSU output as it is, I might hold off
Edited by bozodos
here's a result with the latest drivers; for some reason I can't push the cores any further or 3dmark freezes, strange given that could get the first card up to 950mhz :/
also swapped in a pair of Sata 2 Velociraptors in a 128k stripe :D
http://3dmark.com/3dm11/1670000;jsessionid=5hzujouc0u8l?show_ads=true&page=%2F3dm11%2F1670000%3Fkey%3Dbn39BVvDMH7dx
Anyone ever used a phase change cooler? I used one for about a week, until the moisture fried my mobo because i had the heater hooked up incorrectly :angry:
I was running 4.8ghz with an i7 920, fully loaded on prime 95 temps were less than 10 degrees.
Quick question I'm hoping someone can help me with; my asus P8Z68-V has 2 switches on it. One activates TPU (auto overclock) and the other activates EPU (a power saving feature). Does anyone have any experience with these features or know anything about them? Not sure if I should switch them on or not.
I've a similar board (P8Z68-Deluxe), I presonally don't bother with using them.
OC is best done manually anyway (espeically if you have got a i5/i7 unlocked CPU since its super easy) & as for the power saving thing... to me thats like saying I'm buying a Skyline to save petrol. LOL
  • 1 month later...
question for the nerds.
currently running a 8TB server in a Thermaltake M9D chassis. but i have managed to clear a bit of space in this room for a rack mount server.
however, i do not know a great deal about rack mount setups.
What i would like to do is transfer all the gear out of the M9D into a rack. is this possible? or would i be looking at having to buy a server board, and going from there?
I personally wouldn't recommend a rack case in a home environment. Their cooling is typically designed for an enclosed rack environment in a datacenter with cool air at the front, exhaust at the rear. They often used very small high-speed fans to facilitate their cooling - and these fans are usually very very loud.
What exactly are you trying to achieve?
exactly
It's a pity though, we have a heap of old 1 and 2 RU Xeon servers that are sitting under benches for this very reason - they are outdated but impractical to sell, and not able to be used in a home environment (without a lot of stuffing around with racks, cooling, soundproofing etc)
need more desk space, and i've never been keen on putting the towers on the ground
but if its not fiesable, then its not fiesable :). just curious to see if it was possible, as i could just mount it to the wall
Yeah rack really isn’t an option. My tower sits on carpet mate, and has for quite some time. I mean it has “legs” so its not sitting bottom surface etc. Can’t see why you cant do that. Also keeps cabling out the way.
How many drives do you have?
4x 2TB
or 8 x 1TB
Running RAID cards? Or JBOD?
If it’s just a JBOD server, a 4-bay m-itx option like this would be a good idea
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=16066
I’m not totally up with m-itx boards, so not sure if they have onboard RAID or you need a RAID card. If you do need a card/more drive space:
(ive not totally checked space/specs tho)
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=18323
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=14503
Despite what the muppets have said, yes you can get a rack case that doesn't have high speed fans and it would be fine. Decent ones are pretty expensive though and it wouldn't really be worth the money.
Yeah rack really isn't an option. My tower sits on carpet mate, and has for quite some time. I mean it has "legs" so its not sitting bottom surface etc. Can't see why you cant do that. Also keeps cabling out the way.
4x 2TB
or 8 x 1TB
If it's just a JBOD server, a 4-bay m-itx option like this would be a good idea
http://www.pccasegea...oducts_id=16066
I'm not totally up with m-itx boards, so not sure if they have onboard RAID or you need a RAID card. If you do need a card/more drive space:
http://www.pccasegea...oducts_id=18323
http://www.pccasegea...oducts_id=14503
i've noticed that when the towers sit on the ground, there seems to be more dust in the cases in a shorter period of time ( from the carpet i imagine).
at the moment both cases get a dusting every 6 months, unless i'm fiddling with them. then they get a dustout while the covers are off.
4x 2 TB at the moment. but theres another 2TB drive waiting to go in. once that goes in i'll be putting it into a RAID, probably something like RAID 5
the server was built to make use of old parts, and extra storage ofcourse.
cabinets i've seen are around $600 + freight
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
