made 427.9 kw last nite on 25 psi dropping to 24 and with a couple of little misses
built 26
272 cams and asorted head work
t88-33d turbo
for some reason power starts to drop off abit at 7250rpm instead of still climbing
built 26
t88-33d turbo
What is the T88-33d like; full boost when and what size ex. housing?
its laggy but its soo fun on boost, i love it. it drives around normally quite nice in my opinion
full boost at 5900rpm all way to 9250 redline
18cm exhaust housing
i had gtrs' before i got the motor built and its alot more fun to drive. love the sound of an open 60mm gate that goes straight to atmosphere
Yes; that is late on boost. I wonder how the 15cm ex. housing will go at improving it? If you are not fussed guess it doesnt matter.
I think you should post a video though so everyone can enjoy the open gate to atmo :)
im not spending any more money on my engine. im happy with how it is
just gotta get my brakes upgraded and thats it, car is complete
no vids of runs. fone died at work and had nothing to record with
What setup have you got for cracking the 4's?
I'd happily take you if mines ready, it's pretty much impossible to be there though cause it's not long enough to get the work done. If a late night happens on Saturday and it's all good I'll pm you. In saying that I'm expecting to need a lift aswel so tgeres no need for the supra
Cheers steve..
The current setup is a built 26 ..forged pistons,stock rods with arp bolts, N1 pump with nitto gears,heavily ported head with JUN 9.5 268 & large valves, ported & ceramic coated stock exhaust manifolds, modified hks 2530's ,R34 dumps, id2000's & haltech platinum pro.
If 2 bar of boost doesnt see it crack 400 then E85 should do it.
It's nothing mega, that one will come later..full counter 2.8 crank,pankl titanium rods & the head from the current one.
Cheers steve..
Yep confirmed, zero chance of it being there
Pankl rods? Oh pics please! They're no doubt obe of the best available. What stroker do you want?
If all else fails, add boost :P
built 26
t88-33d turbo
when are you going to WSID? i wanna come watch :P
the drop in the top end might be cam timing, the tuner might have it setup to help with response but will suffer in the top end a little.
my old GTR 419kw had the same little misses your talking about, boost seems to blow the spark out especially 25psi
I like your attitude!
That's where most people go wrong...... go with what makes you smile! not what spools up 100rpm earlier...
i wont be going up till early next year. heaps busy with work atm and other things in life so that will be the earliest.
knowing me tho ill probly do a few more tweaks here and there before i go, i just cant help myself.
looking at breaking into the 10s when i go
even with the power.... 10's aint as easy as it seems.
thats right, heaps of people told me it would be shit to drive but i havnt had a single problem with the way it is.
there was only 600rpm difference between my gtrs' and the t88 for full boost so im not going to let that bother me at all.
maybe later on if i want to track race ill go low mounts again but untill that day im not looking back
yeh i know. i went 11.4 with average launch and bad 1st to 2nd gear change. that was with 400kw
so since thsat have had another tune new fuel system and os giken gearbox
Might be 600rpm difference between your GTRS' but full boost at 5900 is at least 1800rpm difference between most T04Z results on a 2.6L
and making the same power at the same boost...
i have a to4z and i think i get full boost just before 5000 , that's on a 2.6L with fogies and complety stock head.
personally i wouldn't be putting a to4z on any thing with out some serious head work and preferably stroked a bit.
i.e i maxed out my 023 bosch fuel pump on 16psi lol , that's not even in the turbos affections
you mean efficiency? ^^^
T04z should be running a .82 rear housing, mine had a 1.0 rear and was on song at about 4750ish
mine made 419KW on 25psi,
ive heard stories of ppl making the same power with a .82 and less lag.
T88 would be pretty sweet as it ramps onto boost and then fry tires,
yer i have the 0.82 , any idea why mines a tad more lagy?
i have std head , do u have a std head?
cant remember if i posted it in here ages ago but mine has gone 585rwhp on 18psi and 98 pump, t04z, 2.7L, extensive headwork and big cams. It also made 605rwhp on 22psi but was misfiring so backed off early. I ran 11.3 @ 124mph in a 1740kg car when it made 520rwhp on same dyno.
The new car in nearly ready to run again with this engine so looking forward to seeing what it can do.
Yeah mine had standard head. Just drop in poncams and cam gears.
I havent hadthat car for about 3 years so my memory ofthe lag isnt the best.
Just to rub it in guys my current (near stock)GTR has a whopping 285kw and runs 11.7.
Just to make u feel glad u spent all that money to gain half a second like i did in my last GTR ;)
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
