For it to be closed loop it will need a signal input from the camshaft position sensor that you will need to install. You can't just use RPM as an input for closed loop as it's unrelated to what you are adjusting
I thought he was talking about open loop control, but yes if closed loop you obviously need an input as well.
We are looking into an rpm box for you guys.
I've been using the msd rpm switch for a while now... sturdy bit of gear.
I'm suuuper keen to get a hold of 25 VCT conversion parts and camshaft from you once it's all sorted. I'm suprised no one has developed it yet???
Do greddy still make the adjustable cam sprockets for the 25 vct cam gear?
sign me up-
Cheers
Justin
I'll look into that thanks.
The factory RB25 inlet gear is adjustable....it's just on the back of the gear :(
I have seen someone do a bolt configuration through the gear so it was adjustable from the front.
The MSD RPM switch looks like it only turns something on at a specific RPM? We need to turn it off again at a certain RPM so that means it would need to be programmable
Look for a MSD RPM window switch, a RPM Switch is on... A window switch is on and then off :)
I'm just using a on switch mind you, works fine
Thanks.
They seem to be what we were looking for. And only about $150 so also the right price.
what intercooler, are you running??
His car has the basc 70mm ARC GTR intercooler. They're a good bit of gear. Light, good flow and good cooling. They are actually lighter than a stock GTR intercooler!
i was pointing more at v8 vvt that run 4 cam sensors
like the bmw's and soon to be nissan v8's
run them as pairs in/in ex/ex not often you want different valve timing event between left and right banks.
Thanks.
This is what I use:
http://www.msdignition.com/Products/RPM/Timing_Controls/RPM_Controls/8969_-_Digital_RPM_Window_Switch.aspx
Cheers :cheers:
J
Woudn't trust a eboost to switch anything on, they are a POS at the best of times
cheers
darren
Mines works great, what is the issue you have with them?
Controls boost well, window switch works great, lots of people recommend them?
I've never had problems with the unit or the solenoids on, only the people who wire them in incorrectly. I'd say most people's grief would be caused by the same thing
They have a bad habit of just locking up , outputs stop working at same time and you have to send them back and get them updated.Eboost 1 and 2 do it. ... I am not the only
one who had that problem, a mate had the same problem , and if you look around, a lot of the sport compact racers have had the same problem
Its actually quite common and a lot of workshops won't use them for that reason, as i found out after mine f**ked up.
Not good when its hooked up to your water injection solenoid that for sure
I wound't buy a second handy of ebay, thats for sure!
When it worked it did do a awesome job of boost control, funnily enough mine got stolen out of my car when some work was getting done to it, before i had a chance
to get it updated, hopefully it blows the thiefs car up ..lol
cheers
darren
Edited by jet_r31
i've got 2530's, which are almost identical, and with baby cams still managed 400rwkw with E85, only 21psi as well - most people run 260 cams, and prob more around 24psi is the pistons/everything else can take it, you'll walk in the 400 with -5's :)
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
