Interesting stuff Ash, its amazing how much climate can effect things. What RPM does this happen for you with an Rb26?
Indeed usually up in the hills a bit as well is when it does it, so temp and probably pressure both factors.
It's just as turbos are starting to come off Vac so around 2000-2500rpm if i had to guess. Just as the boost gauge moves into positive is when it starts.
Only been up/out in that weather twice since I've had the car. Even @ Mt Baw Baw, when it was quite cool but not under 10deg even with altitude
I ran a hks superdrager which was 3.5inch supporting 505awkw on 98 and now I run a veilside evolution full system which also is 3.5inch supporting 390kw on 98.
My mate bought the BSM GTR and surprisingly it runs a 3inch titanium system and that runs a 1000hp engine. I had a good look at it a few weeks and it is ultimate in gtr's :) what a weapon!
all Midori, s/s front pipes and and Ti catback - Sard cat. not sure on the diametre though, and it would be listed in mm too.
as for ECU, Link G4 plugin :) - unless it's a really serious build, Ling G4 Xtreme, but obviously that's a wire-in job. I think there are some sort of harnesses floating around for the 26 though...
Link G4 is popular with the tuners I speak to lately, and not much more expensive than what alot of people want for a second hand power fc!
Not when you factor in $600 ish Nismo AFM's ontop of your 7-800 for a second hand Power FC. It's really a no brainer. Yes the FC will do the job but the higher end ECU's like a Autornic SM4, Link/Vipec will do it much better.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
