Spool 3.4L Kit
RB26 head with 260 10.8 Procams & Supertech valvetrain
6boost & Progate 50mm
Precision 6466 1.0AR TS
Haltech R34 GTT Pro Plugin
Bosch 2000cc, Twin 044's
Caltex E70
26psi boost
I have a detailed build thread in the projects section :)
  • Like 1
Why stop at low 10s? lol.
9s and around then 140mph you'd think with that power! Just gotta get the power down to get the ET, or put streets on and just get the MPH for laughs if you're only going to get kicked out anyway :merli:
LOL 150MPH is serious power in any chassis, I believe "JUN" the R32 GTR was doing that or a bit more with almost 800rwhp. The car posted above should be in the 140-144MPH range, no more.
Can finally post in this thread as I was 9kw off before haha
Car went 11.5@125 with 391rwkw on Nexen street tyres (heh), hope to break into a 10 and some more mph with ET Streets..
wrong thread.... haha
http://www.skylinesaustralia.com/forums/topic/411489-500kw-club/page-10?hl=500kw#entry7106197
Ahh, the old dyno VS blacktop scenario.
On another note I just had a exhaust fitted to the 5, after a few more mods and and a dyno run I might start looking for the "got over 100 kw atw" thread......
  • 3 weeks later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
