I've always liked the xr6 turbo BUT there is a trade off... my mate made 390kw with his and blew many transmissions, diffs and uni joints. What a torque monster though
Drop that donk in a gtr (only if) = win :)
The BF and FG will make >400rwkw with the stock turbo, exhaust, diff and gearbox all day everyday, the BAs won't handle more than 250 before blowing both of them up though.
Haha, I to thought about putting the Barra motor in a GTR and the adaptor plate wasn't really an issue, the hieght of the 4.0 on the otherhand with the 4WD sump will pose a few issues :(
You would definitely need a massive bonnet bulge to fit it in, quite a tall motor.
I made 300kw in my BA when everything was pretty much standard. Gearbox and diff lasted less than a month haha. I guess that's what you get with 1000 odd NM.
PS: An FG XR6 won't make 400kw with a standard turbo but the F6 will.
  • 6 months later...
Racepace built rb26
PTE 6262 twin scroll setup
6boost manifold
Stock cams
Id1000's
E85 + twin intank Walbro's
Power FC
This was on 23psi
probably a bit more boost in her too
Do you have an RPM graph for the X axis?
would love see what rpm boost and power is made
Good thread revival Buraz!
How did u squeeze 2 intank walbros? Do u have 32,33 or 34?
It's an R33 Gtr, Racepace did all the fab work and all the fuel setup. I couldn't exactly tell you what adapters etc they used, i didn't see it all while outside the car. I know they made it all in house and there was lots of work involved.
This is the only graph I have!!
Probably is but didn't want to push it, engine has lots of track days and kms on it since rebuild I just wanna keep it safe until I have it freshened up.
Even with a Nitto 3.2 I could not make it :no:
But have not given up just yet :unsure: this was 98 pump
Going to upgrade the fuel line and exhaust. Do a flex tune , should make it on 98 and then see what E85 does to the Graph ????
  • Like 1
Racepace built rb26
6boost manifold
Stock cams
Id1000's
Power FC
This was on 23psi
What AFMs are you using there?
everyone in this thread good at changing boxes?
I'm up to 4 broken after doing 2 in a weekend at Racewars not long ago
So far I've stripped 3rd gear twice, sheared the input shaft once and the latest appears to be a broken reverse/5th selector fork.
In saying that they only ever break when no mechanical sympathy is shown, if you are gentle and select the gear and the roll off the clutch they seem to be fine (as oppose to smashing through gears and kicking clutches)
Edited by SimonR32
make well over 400 man.
Apart from the problems I have had since the build it goes pretty quick now , very linear. Feels great on corners, no surprises/
It will be interesting to see how a bigger Dump and Cat makes it respond and what it adds to the overall performance :/
It will make a more then noticeable difference pete
Hi Joey, hope your right, hate wasting money.
There seems to be 2 different opinions on this subject but I am going with what you blokes have told me from your experience as I like first hand feedback not from books:)
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
