Head was fully reconditioned but no porting was done. Tomei type B valve springs and new bronze exhaust guide inserts. Grex 264/9.3 cams. Tomei cam gears.
25psi boost.
BP 98 fuel.
Built and tunned by Jim at Dart Automotive.
It has plenty of response and mid range. Very happy with it.
Tim.
This is my build thread but it hasnt been updated with new dyno graph above.
http://www.skylinesaustralia.com/forums/32...ld-t320793.html
Edited by R32 Zilla
good work, its definately got a 10 in it with a good driver :down:
definitely!
i did an 11.1 with 320awkw (if i changed into 4th across the finish line & not hit the limiter in 3rd, it would have been a 10)
with 390awkw it is well truly a mid 10
Give us a chance! haha. I only got 3 runs the other night before it rained and it was called off. I was getting faster with each run. We were slowly dropping tyre pressures. Got an 11.21 @130 on the last run with a 1.78 60ft. As some of you know its not as easy once you get up around this power especially on street tyres. With my old motor it was just a case of giving it everything to reach its potential. But yea it is easily capable of a mid to high 10 with either some more practise on street tyres or a simple tyre change would get me there.
This is no drag set up though. If I wanted it to be faster over 400m I would have chose different turbos/turbo and made 500kw which this motor could easilly handle. I chose the -5's for response on the street and for hill climbs and the circuit etc. I like corners.
Oh and the 390kw is RWKW not AWKW Marko. I dont think that makes a lot of difference but lets not start that debate again haha.
Tim.
i ran 10.98 @ 130.7 mph with 405awkw, on old street tyres, federal 595s. and worn out os giken clutch,
last week with 285kw stockis R32 GTR just power fc,exh, steel wheel turboes, 3/4 tank of fuel, spare wheel, jack, all interior in etc ran 11.7 @ 118mph on my 2nd run, got booted out cause i didnt want to renew my ANDRA licence,
i spent over 45g on my last GTR to get 10.98, my new GTR i have spent maybe 4g, big difference in costs to get from mid 11s into the 10s
oh and i didnt mean to start a big war on rwkw to awkw :P
Just a question that is kind of related to here; in my quest to get to 400kW :(... does anyone know if you can use Supertech bronze manganese valve guides with Ferrea oversize valves? Ferrea don't make any for the RB26 apparantly.
I dont see any reason why you couldnt.
I may actually be able to join this list very soon!! things are finally looking good! tho it may be steves 500kw club!
i will be going GTRS on a built 2.6, 280 10.8's, E85, CR box with as much boost as it will allow 2 bar close.. then back it off to keep things together haha.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
