  • Replies 2k
my good mate has an '83 HR30 2000GT Skyline sedan
L20ET motor, full 3" exhaust, 7mgte front mount cooler, 1bar boost, DR30 tail-lights, goes quite hard.
just gave it a cheap respray from grey -> black.
heres some pics.
https://www.sau.com.au/forums/topic/25761-r30-skylines/#findComment-557210
yeah it REALLY needs to be dropped, i keep telling him, hes lost his lic for 3 months so i guess he'll do it soon. the rear rims are just painted s13 ones, the fronts are also painted, some jap brand M's or somethin. he used to have the whole set of the front rims, which were silver, but he mashed them on curbs :D
he sanded it back himself and prepped it a bit before the respray, cost him $500 for the respray incl paint. up close its a little rippley where looks like paint has been applied too thick in one go, but apart from that looks good, cant go wrong for $500 i spose.
https://www.sau.com.au/forums/topic/25761-r30-skylines/#findComment-558571
well at least its still going as there are not to many people who know to much about the r30 who don't live in jp but i would be interested to see about getting the instrument panel, my car is identical to the red and black dr30 for sale on the home page of www.r30.co.jp so it has the front bar but would like the extra part they have for sale as well.
https://www.sau.com.au/forums/topic/25761-r30-skylines/#findComment-559128
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
