Can anyone solve my riddle???
Brake lights don't work when brake pedal is depressed.  All fuses checked.  And Brake pedal switch has been replaced.  Why won't my friggen brake lights work???  With all this rainy weather, its too dangerous for them not too.  Already almost been rear ended about 6 times.  They light up when headlights are turned on, but just dont come on brighter when braking.  Any suggestions???
Follow the pedal switch back to the brake lights, it may have been severed at some point. Also there is a little black box mounted in the boot on one of the taillights, (right side i THINK) which can fail, check the system with a test light before and after this little box (its about 5cm long and 3cm x 2cm)
  • Replies 2k
i went 248 on the freeway in my S13 ... but its how quickly u get up there that gives the thrills! and how much wheelspin haha
hmm the lights thing does maybe sound like an earth problem or something not properly connected since theyre coming on so the circuit must be getting power, but just not lighting up properly when depressing the pedal. check all the connections into the lights like has been suggested then if that fails try and trace the earth cable.
tho an auto ellecy would probably be fairly speedy at tracking down a problem such as that i would imagine since its fairly clear what the symptom is and there cant be *too* many possible causes !
i saw a picture on Yahoo! Auctions Japan for a DR30 for sale which had the rear windscreen wiper removed .. looked pretty smooth so i thought hell ill do that to mine just see if i like it for a day or something coz i never use it anyway even in rain haha so i took the nut and wiper off and drove round and wallah, lost the black dust cover thing that goes over the bottom part of it lol ****. im too much of a fidget for my own good sometimes. o well :) wiper stays off now :) the thread stickin out does look a bit wierd from up close but from a distance it looks quite cool without the wiper .. smoother and more symettrical (apart from huge exhaust and badges haha)
It couldn't have been the panel beaters, as they didnt disconnect anything. Like Crimmo said, it could be that little black control box, thats the only thing I didnt check (although I wondered what it did!). I had a good look today at work and I know the taillights were changed after it was imported coz they were cracked. There are two left over wires either side with provisions for a push in type 12V globe, I put globe in these and tried the brakes but it did nothing.
Anyways to cut a long story short its going down to auto electricians tomorrow morning, they will definetely sort it out in like 10 minutes I reakon!
..snip..
Yeah I had a weird one, took it to the sparky, took 'em half an hour and it turned out to be a wire burnt out in the dash when some dumbarse shorted something and burnt out a couple of wires
Hey Mate,
Don't suppose you know what sort of speed you were carrying at 6k? Have you got the stock rear end in it?
Cheers
Rob
Sorry i dont know the kph,as the speedo only shows 180kph,and when your shifting at 8000rpm the speedo passes 180 in 4th gear.It has a 4.1 R200. One of the reasons its so exciting is the fastest part of the circuit is up and over a hill which means you have to brake on a short incline at the bottom of the hill...awesome.
No mods needed....Wolf needs a reference hole drilled in the disc so it can see No1 position.
Came 6th outright(55 entries) and second in class at the weekends sprint event.6000rpm in 5th down the straight is the best drug around. :D
So how exactly does the wolf run your car??? I just got offered a V4 last night for a cheap price and im pretty much gonna take it...
Got my brake lights fixed, and it turned out to be what Crimmo suggested (and the only thing I didn't check!) that little black box on the RH rear tailight. Apparently its just a sender type unit that tells your cluster whether any of the lights are out. It was all melted and fried on the inside! All they did was take it out and bypass it.
On another note I woke up bright and early this morning to take my radiator out. Its in getting fixed up as it has a small pin prick on the top tank! Hopefully they can resolder another top tank on or fix the old one, just don't want it to cost the earth!
Talking about top speeds, the other nite I gave the Skyline a blast and wound it off the clock past 180 doing about 5500-6000rpm (didn't get exact rpm as was concentrating on Prado I whizzed past) :whatsthat
i'm on the final straight now:) car goes to auto electrian on mon to fix a few things then new tint and last to get the seats fitted and complied then i'll pick up my new plates:) :D once on road it'll get some waiting new bits...
I know my car used to do 180 in 4th at about 5900 or somethig like that...Then the big brick wall!!
Got my new turbo tuesday as well boys, taken some foto's, just have to upload them to my website which should be done this arvo!!
Had a similar problem with my car as well now that i think of it
its a small box about a size of a packet of redhead matches right? Yeh mine was absolutely fried as well and bypassed it. Brake lights worked though, just the night lights didnt, made my car a little-too-stealth for my liking :)
so basically it was a dawn-till-dusk car until i got that fixed.
Yay got myself a set of coilovers. Gearbox should be going in this week some time if I get off my ass, diff should be getting done next weekend, It's all coming along slowly very slowly. Just need a tailshaft made and thats the drive line done. Then all the rest of the suspension... and the list goes on.
What does everyone think of one of these turbo's on an FJ???
http://www.atpturbo.com/Merchant2/merchant...tegory_Code=GRT
Yes GT2871R is a GT28 turbine and a GT35 comp wheel . If you look at the GT28RS at this site its what I ran . The only prob with either of these is the T25/28 flange . ATP also do a T3 exhaust housing actually GT30 internally but profiled to the turbine used by the GT28RS and GT2871R (same) . In theory you could use an integral waste gate with this housing , but not your original FJ gate . You need to understand that the std exhaust housing was made by Nissan to suit a Garrett core and so the stud patern on the back of the exhaust housing is different . However the Garrett style gate is easy to find .
The turbo I really like is the GT3071R , T3 flange and GT30 turbine . It uses the same comp wheel as the GT2871R and could probably also use TO4B comp cover if space was a problem . Lots of good stuff at this site but none FJ specific .
Cheers A .
my car is for sale guys, asking 10k, spent well over 15k in mods.
No photos yet, but they will be coming soon
Nissan Skyline R30 4D Metalic Gold - Series 2 (New 2pak paint 12 months ago)
'93 RB20DET
VG30 Turbo
Stainless bar and plate front mount intercooler 450*300*75
3" mandrel bent turbo back zaust system, kakimoto box
TJ unsprung racing multi plate clutch
JIC height adj. suspension all round (camber adj. front)
R32 4 piston front brake setup
Mech R200 LSD
K-mac sway bar
Bosch 044 fuel pump
Custom made oil catch can
Watanabe RS-8 in 16x8 on all corners
4 point half cage
Turbosmart electronic boost controller
Blitz boost gauge
More mods ive cant think of off the top of my head
Adam_RSX - yeh that was me :)
Has anyone fitted a Turbosmart bleed valve to their FJ20 at any stage. I fitted one today, and it lifted the boost from 0.3 bar to 0.6, which was all a wanted to do, but at high revs when under load, it is like the factory BOV is opening up and venting for some reason. Any suggestions???
I think it is coming from the RH side of engine bay, and at first thought it was a boost leak, but double checked hoses and everything was fine.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
    • I don't know what you should expect with an LS, but the oil pressure sounds terrible, sorry. As for the brakes, you can get fade from the pads not just the fluid, although generally that feels like a wooden block not doing anything while fluid feels like an oh shit there is no pedal so you can generally tell. What pads are you running front and rear?
    • Went over my datalogs on a whim and noticed a worrying combination of events. High RPM High Temperature Low Oil Pressure Knock Retard I bought some 10w-60 because I actually think this will be better going forward given track temp is 125C and 10-40 will actually be thinner in those environments. I know I had a leak but it's not entirely sure how much pressure loss can be attributed to that. The knock retard does correlate with all of the above. When it's not present oil pressure is higher. And by 'low' I mean at 6800 RPM the oil pressure was recorded as low as ~35psi pretty constantly. Which is obviously very not good. I'm hoping that thicker oil that ISNT LEAKING will result in a bit more pressure when I need it. Also in the last session I got a very spongy break pedal. I bled the lines as the car is on jack stand right now with the wheels off and I noticed... no air in the lines? Maybe the tiniest bit of tiny frothy bubbles for the first 0.1 seconds of bleeding the whole car? The breaks did come back to me after I backed off (and felt fine driving normally). Doesn't appear to be any leaks anywhere that I can see. Any thoughts on that?
    • Solution, run shitter tyres. Let wheel spin be your weak link 😛
