Sometimes i wish i'd bought the 3037 instead of the GT-RS.
Best decision i made was to get the 3037 .68 rear, making 337 on E85. Still responsive too....
  • Replies 489
How much was it?
I brought mine off a fellow member and the turbo had 5000k's on it, from memory it ended up costing me $3200 for the complete kit. Not too bad considering what they are selling for now.
Good price that.
Bought my gtrs for $2750 2 years ago.
anyone got a set of indy blu's i can throw in and use the e85? ps. anyone used 100% meths? (chemcal factory next to my work can get it to me for $1.20/L
i was going to go methanol on my sr20, problem being the maintenance required. Any decent power WILL require 2 sets of indy blues per cylinder. Most people in the know say big electric pumps are OK, but mechanical driven is much better. But then they are a flamin mongrel to start with mech pump and you need to gravity feed the fuel in (thats why they run small tanks in the engine bay) then you need a special mech pump reg (not big deal). but then you need to drain you oil after each event you run at (mostly) run normal petrol through fuel system and run the engine or you will corrode the bores etc. "usually" dont run filters either as they can trap meth and turn to jelly.
Edited by GTR1993
Give it a try, might need 2 rows of indy blue's to make real big numbers!!!!!
Brazil's been useing 100% for years, would need high ambient temps to get he stuff to fire tho, even 85 gets hard when temps get below 10 degrees
good result, but I would love to see a graph of what difference it made at the same boost. I know you're saying you couldn't run more boost with the 98RON, but it was only running 14psi at the top end with a spike to 21psi as it ramped onto boost. I would just want to see what gain the fuel itself made. same boost, but with more timing etc it can apparently take. as it is a lot of that gain would be from more boost (more air + more fuel = more power of course), and i'm a bit surprised that the most you could run was 14psi on 98RON.
anyway, enjoy the new power and sweet smelling, cheap fuel. :glare:
sorry... on 1 bar the e85 made just on 300 by memory...
i cut the boost on each fuel @ the point where it was starting to die off... (dont wanna run 2 pounds more to get 5rwkw gain)
price not my main concern, it's all about the RON man, oh and the huge torque that 24 psi offers, love it!
I can agree to this.
It definitely doesn't have that typical weak RB25 ramp up sound when on the dyno. 180or200's car had me thinking it was an rb30 the way its mid range picked up instantly and roared as the loud pedal was opened up.
Thizzle made 301 with a GT-RS and stock motor 3 or so years ago.
There is hope!
I'm with Ash; sounds like he was on a happy dyno or the settings were incorrect. Did he ever back the power claim on an independent dyno?
I made 274rwkw with cams and head porting. This figure was also reproduced on two other dynos, so i dare say it was accurate.
With E85 i could see the GTRS making 280+rwkw on a std motor.
On the DVD it made like 298, 297, 301 or something along those lines.
But on the same dyno.
To back up the claimed figure it needs to be run on another dyno.
Like mine made 274@EAS, 268@Racingline (SAU VIC Dyno day) and 272@Autosalon. Thus i know my mechanic's dyno is relatively accurate.
Nice results :devil:
Excuse the ignorance, I haven't bothered to read anything about this fuel...
but 85% ethanol? People were pissing and moaning about 5-10% ethanol destroying fuel systems etc (I personally ran V-power racing for a period of time with no issues, and 1 tank of 100RON United which I think has ethanol as well, with no issues) but 85%?
Has this question been addressed? Also, what is the equivalent PULP RON (if such a comparison can be made)?
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
