lol problem was .63 dropping. not .82. PU comes in both .63 and .82 depends on what people wants. Also I had a customer making 21psi to red line in .63 internally gated. I'll be seeing this guy's car on the weekend and should be able to sort it out.
We have an example here. SSGOhan here's running a high flow with a OP6 housing with a 20psi actuator. See what’s happening here? his getting 18psi with no boost controller and experience a boost drop to 16psi at red line.
thats fine, and its SSGOhans car and results that we are trying to replicate with mark and nicks car, 18 dropping to 16 (i have all daniels graphs) is fine but we are getting 18 dropping to 12 with the actuator that was supplied hence i asked mark to upgrade.
I understand it is never going to hold till redline with the 0.63 but the increase of boost from 12 to 16 with the bigger actuator could give us as 20-35rwkw.... a great outcome.
Hi Trent. you mean Ricks car? he's definently have the high pressure actautor, I tested it on front of him before putting it on. He's also got the wastegate controller installed, Have you had a play with it on the dyno? That will hold 18psi red line.
Also he's turbo is in a totally different profile to either Daniel or Mark. It will be the most responsive out of all 3, How ever marks should have the highest torque.
I will check mark's actuator and few other things this weekend.
Plus do you still remember that light blue R33 you workedon towards the end of last year? that guy's got exact high flow profile in .63 turbine a Marks with the same actuator. He's holding 21psi to red line. Did he came back after running into few trees? (he said he had an accident when I rang for some feedbacks.)
Its just strange same actautor on the same turbo gives all sort of results on the same type of engines.
Few photos added in modifying intercooler pipe to suit a BOV. Photo shown the driver side pipe that is connected to the outlet of the cooler.
Its a HPVA BOV. We make them as well.
As some of you've might seen. This is ATR43G4 in .82 turbine housing Running internally gate with high pressure actautor.
In generally you will find .82 turbine housing and high pressure actuators work pretty well on RB25dets. made 321rwkws@22psi.
so i have an r34 rb25det neo, and i want to upgrade the turbo.
I have all supporting mods to get to 270rwkw, but I'd rather have like 250 with better response. So can you recomend a turbo ATR43G2? or could i get that result with my stock turbo highflowed?
We can do a SS2 high flow to your stock turbo. which will make 260rwkws with stock standard response. Every thing bolts back on with no modifications required.
funny that the 3071 keeps pulling past 7k yet the others dont...
Please see this thread for which cars were selected etc:
http://www.skylinesaustralia.com/forums/Qu...urbo+comparison
Its far from a perfect graph. It took me a lot of time, feel free to make your own thats better. These are all real dyno graphs.
I just used it as a way to show the pre 3000rpm performance of the stock turbo.
I've high flowed few in 2860RS spec. and it was more responsive then stock.
SS2 is a T3x .63 rear running a 2871RS spec CHRA in 52T comp using Stock housing. will get full boost by 3000rpm and max about 260rwkws.
Also Waste gate lever controller for stock R33 turbo high flowed units. Controller is optional, and cost more to make.
(note: Wheel profile made to use with this type of turbine housing is different to standard high flowed units. Slightly more lag, lot more top end.)
how does mine compare to this Stao?
I see you have changed the position of the wastegate controller, much better :D
hello stao
ime interested in your atr43g3 with .82 rear for an rb25det r33, and also your atr43g2 with .82 rear what is the diff between the two. me chasing 280 300rwkw.
ive been looking at garretts gt3076r and cant decide between them or you. what would u have close to that
and also would a .63 rear be cappable of my power goal. and what sort of lag would i be looking at between the .63 and .82 rears, thanks.
We can supply all Garrett BB CHRA in what ever combinations you want.
The GT3076 56T running .82 housing with waste gate controller will get you about 300rwkws at 23psi. We can build this model based on a .82 T3 OEM bolton turbine housing with .60 Garrett anti surge comp housing and a big can actuator for $2200 including GST. All your stock lines fits. You see full boost about 4200RPMs with this model.
The sleeve bearing of above is ATR43G3. its about 200RPMs laggier, archives identical amount of power and power curve.
With .63 turbine housing we recommend a custom 3576 or 3582 profiled running .70 A/R comp. It can get you around 290rwkws with better response through gears.
what would the atr43g3 be like at 18 psi
and this is $1450 against $2200 and ile only lose 200rmp of lag.
is the afm the same diameter as the inlet. and u said i could achive my goal with one of these was that with .63 or .82 rear
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
