lol problem was .63 dropping. not .82. PU comes in both .63 and .82 depends on what people wants. Also I had a customer making 21psi to red line in .63 internally gated. I'll be seeing this guy's car on the weekend and should be able to sort it out.
We have an example here. SSGOhan here's running a high flow with a OP6 housing with a 20psi actuator. See what’s happening here? his getting 18psi with no boost controller and experience a boost drop to 16psi at red line.
thats fine, and its SSGOhans car and results that we are trying to replicate with mark and nicks car, 18 dropping to 16 (i have all daniels graphs) is fine but we are getting 18 dropping to 12 with the actuator that was supplied hence i asked mark to upgrade.
I understand it is never going to hold till redline with the 0.63 but the increase of boost from 12 to 16 with the bigger actuator could give us as 20-35rwkw.... a great outcome.
Hi Trent. you mean Ricks car? he's definently have the high pressure actautor, I tested it on front of him before putting it on. He's also got the wastegate controller installed, Have you had a play with it on the dyno? That will hold 18psi red line.
Also he's turbo is in a totally different profile to either Daniel or Mark. It will be the most responsive out of all 3, How ever marks should have the highest torque.
I will check mark's actuator and few other things this weekend.
Plus do you still remember that light blue R33 you workedon towards the end of last year? that guy's got exact high flow profile in .63 turbine a Marks with the same actuator. He's holding 21psi to red line. Did he came back after running into few trees? (he said he had an accident when I rang for some feedbacks.)
Its just strange same actautor on the same turbo gives all sort of results on the same type of engines.
Few photos added in modifying intercooler pipe to suit a BOV. Photo shown the driver side pipe that is connected to the outlet of the cooler.
Its a HPVA BOV. We make them as well.
As some of you've might seen. This is ATR43G4 in .82 turbine housing Running internally gate with high pressure actautor.
In generally you will find .82 turbine housing and high pressure actuators work pretty well on RB25dets. made 321rwkws@22psi.
so i have an r34 rb25det neo, and i want to upgrade the turbo.
I have all supporting mods to get to 270rwkw, but I'd rather have like 250 with better response. So can you recomend a turbo ATR43G2? or could i get that result with my stock turbo highflowed?
We can do a SS2 high flow to your stock turbo. which will make 260rwkws with stock standard response. Every thing bolts back on with no modifications required.
funny that the 3071 keeps pulling past 7k yet the others dont...
Please see this thread for which cars were selected etc:
http://www.skylinesaustralia.com/forums/Qu...urbo+comparison
Its far from a perfect graph. It took me a lot of time, feel free to make your own thats better. These are all real dyno graphs.
I just used it as a way to show the pre 3000rpm performance of the stock turbo.
I've high flowed few in 2860RS spec. and it was more responsive then stock.
SS2 is a T3x .63 rear running a 2871RS spec CHRA in 52T comp using Stock housing. will get full boost by 3000rpm and max about 260rwkws.
Also Waste gate lever controller for stock R33 turbo high flowed units. Controller is optional, and cost more to make.
(note: Wheel profile made to use with this type of turbine housing is different to standard high flowed units. Slightly more lag, lot more top end.)
how does mine compare to this Stao?
I see you have changed the position of the wastegate controller, much better :D
hello stao
ime interested in your atr43g3 with .82 rear for an rb25det r33, and also your atr43g2 with .82 rear what is the diff between the two. me chasing 280 300rwkw.
ive been looking at garretts gt3076r and cant decide between them or you. what would u have close to that
and also would a .63 rear be cappable of my power goal. and what sort of lag would i be looking at between the .63 and .82 rears, thanks.
We can supply all Garrett BB CHRA in what ever combinations you want.
The GT3076 56T running .82 housing with waste gate controller will get you about 300rwkws at 23psi. We can build this model based on a .82 T3 OEM bolton turbine housing with .60 Garrett anti surge comp housing and a big can actuator for $2200 including GST. All your stock lines fits. You see full boost about 4200RPMs with this model.
The sleeve bearing of above is ATR43G3. its about 200RPMs laggier, archives identical amount of power and power curve.
With .63 turbine housing we recommend a custom 3576 or 3582 profiled running .70 A/R comp. It can get you around 290rwkws with better response through gears.
what would the atr43g3 be like at 18 psi
and this is $1450 against $2200 and ile only lose 200rmp of lag.
is the afm the same diameter as the inlet. and u said i could achive my goal with one of these was that with .63 or .82 rear
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
