How does the dump fit with a different core on the turbo? or are the cores the same length?
Every thing fits the way it was, they are still your OEM housings. The T2x bearing housing is few mms short. But it doesn't affect installation.
Can possibly high flow it with a BDR351 Comp wheel working with GT45 turbine wheel. Should pump out 1200HP. What sort of housing is it in?
not sure on the rear housing size havent checked yet i would only want it to flow 1000hp anyway would the rear wheel even need changing for that?
Depending on the engine size, for 1000HP you will need a 1.2 A/R turbine housing, and 87mm 85T turbine wheel. The T04Z runns of a 74mm 76T turbine wheel which is rated to 700HP, so it needs to go up in size.
Either way its not a cheap exercise so unless your T04Z is blown, its probably worth selling it and buy the T51R which we can supply at a very reasonable price.
My concern with that is if both cores ar 2-3mm shorter than the gap between the turbos opens up 4-6mm, thats enough to mean that double layered gaskets will be needed or it will leak like a sieve.
Very good result for stock Rb20det, how come its so wavy on the top? ignition problems?
It's a hub dyno so they don't have the power dampened by the rollers which usually smooths out the curve... Plus RB20's always have a bit of a wavy top end
No ignition problems at all (had a lot more boost it in and didn't miss at all)
This was with a G2 in .63, My engine blew up on dyno during the next run. Even thou that made the power and response, I still prefer .82 for high performance RB25det. unless if that was a 3576 profile.
.63 works out ok on RB20dets.
You find Rb25det with .82 rear makes power lot easier with less boost and lot less heat.
What would lag be like though? Could it make 250kw at 120kph / 4500rpm ish like that does?
only cos for me i wouldnt be at the top of 4th much on track if at all (drift), or road so thats why i was thinking the .63 could be better for that reason?
Edited by raZ1911
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
