hypergear Posted September 28, 2010 Author Share Posted September 28, 2010 Stao, what's the main difference between the G1 - 4? If I have the G2 0.82 and am making 285rwkw on 15psi, I would expect similar on 17psi as above. Not that it's a bad thing at all just curious as to my results compared to the above. I guess G1-G4 's all got different wheel profiles and rated differently in HP, Lower HP rated turbo will produce better response. How ever most of our turbos are engineered specifically to what a customer's asking for, so its not really following the guided specs. The twicked ATR43G3 is running a 58T 76mm which was custom made, it seems to flow lot more air down low in a .70 comp housing. It is interesting because larger comp housings has shown greater lagness in my previous testings but it seems to make the turbo more responsive with RB25s. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5469312 Share on other sites More sharing options...
SimonR32 Posted September 28, 2010 Share Posted September 28, 2010 The twicked ATR43G3 is running a 58T 76mm which was custom made, it seems to flow lot more air down low in a .70 comp housing. It is interesting because larger comp housings has shown greater lagness in my previous testings but it seems to make the turbo more responsive with RB25s. I believe mine had a 58T 76mm from memory, but with only a 0.5 front cover... May be interesting if I end up going a RB25NEO to see results with either my 0.63 or upgrade to a 0.84 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5469388 Share on other sites More sharing options...
hypergear Posted October 2, 2010 Author Share Posted October 2, 2010 Need a .82 rear for the RB25det Neo engines. You will find the .63 is restrictive up on the top. Little more updates. This is the result from Harey. from PU high flow with a R34 GTST. Its got abit of exhust and intake restrictions. Final run of 280rwkws @ 17psi 98 fuel. Sheet: As some of yous already seen from the public thread, This is our updated 21U R33 GTST factory turbo high flow profile. I did read many posts in regarding to high flowing with the factory 21U RB25det R33 turbine housings. I did some testing in it with a modified exhaust wheel, I like to share this information publicly and I believe this is the absolute max this thing can flow. I also managed to hold 20psi flat with that small housing using a wastegate controller and a high pressure actuator on 98 fuel. The max power it managed was a stunning 297rwkws when its cold, with final run of 273rwkws consistent. The little sucker was burning red hot. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5476035 Share on other sites More sharing options...
hypergear Posted October 5, 2010 Author Share Posted October 5, 2010 Major update on our media section which contains most of ours and customers dynosheets plus video footages: Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5481478 Share on other sites More sharing options...
boostn0199 Posted October 6, 2010 Share Posted October 6, 2010 Need a .82 rear for the RB25det Neo engines. You will find the .63 is restrictive up on the top. Little more updates. This is the result from Harey. from PU high flow with a R34 GTST. Its got abit of exhust and intake restrictions. Final run of 280rwkws @ 17psi 98 fuel. Sheet: As some of yous already seen from the public thread, This is our updated 21U R33 GTST factory turbo high flow profile. I did read many posts in regarding to high flowing with the factory 21U RB25det R33 turbine housings. I did some testing in it with a modified exhaust wheel, I like to share this information publicly and I believe this is the absolute max this thing can flow. I also managed to hold 20psi flat with that small housing using a wastegate controller and a high pressure actuator on 98 fuel. The max power it managed was a stunning 297rwkws when its cold, with final run of 273rwkws consistent. The little sucker was burning red hot. Video footage for all 3x runs are recorded: I'm little bit concert with high back pressure. So this profile will not yet be commercially available after further testing and examination for component wear. Why is the boost dropping off in the PU hiflow its 0.82 isnt it? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5482583 Share on other sites More sharing options...
hypergear Posted October 6, 2010 Author Share Posted October 6, 2010 That would be from intake and exhaust restrictions and injector seal leakage. Also Trent didn't had too much time adjusting wastegate controller that night. Its getting back on the dyno tomorrow. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5482655 Share on other sites More sharing options...
geraus Posted October 6, 2010 Share Posted October 6, 2010 Toa put some of me on your site to plz and what was my specs again?> heres the vid of me with your latest turbo Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5482719 Share on other sites More sharing options...
Harey Posted October 6, 2010 Share Posted October 6, 2010 Why is the boost dropping off in the PU hiflow its 0.82 isnt it? Yeah I am still sorting some things out. As Tao said lots more to try. We also just discovered the front injector is causing a boost leak so that will need to get fixed before any more testing. I will have more results next thursday. We have a few more wastegate settings to try as well as dropping the exhaust as its suspected to be a bit restrictive. That 279rwkw is actually at only 15.8psi so plenty left in it. Its a bit different to Tao's demo car cause all these things are sorted and you get a direct comparison. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5482777 Share on other sites More sharing options...
boostn0199 Posted October 6, 2010 Share Posted October 6, 2010 Yeah I am still sorting some things out. As Tao said lots more to try. We also just discovered the front injector is causing a boost leak so that will need to get fixed before any more testing. I will have more results next thursday.We have a few more wastegate settings to try as well as dropping the exhaust as its suspected to be a bit restrictive. That 279rwkw is actually at only 15.8psi so plenty left in it. Its a bit different to Tao's demo car cause all these things are sorted and you get a direct comparison. Fair enough look forward to the results. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5482833 Share on other sites More sharing options...
hypergear Posted October 11, 2010 Author Share Posted October 11, 2010 Further updates: This is the very first prototype of our Duel Ceramic Ball bearing turbo CHRA. Its running two air craft caged ceramic ball bearing cartridges in a fully CNC machined billet aluminum bearing casing. Its been then inserted into a GT28 bearing housing for water cooling ability. This turbo is oil and water cooled. Short Video, span by a small compressor. Above CHRA is made to suit a OP6 Rear housing for 500HP high flowing applications. Since OP6 housings are running short I will be testing it in a .63 ATR43 rear housing with a .70 Comp housing. Hopefully it works according to plan. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5490576 Share on other sites More sharing options...
Branelly Posted October 11, 2010 Share Posted October 11, 2010 (edited) Bad ass... Wish my turbo would sound like that. Edited October 11, 2010 by Branelly Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5490834 Share on other sites More sharing options...
hypergear Posted October 11, 2010 Author Share Posted October 11, 2010 Big thanks for a anonymous member who've donated a OP6 rear housing for this project. We will be running it in a real OP6 rear. Looking forward to consistent 300rwkws. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5490987 Share on other sites More sharing options...
too_much_boost Posted October 11, 2010 Share Posted October 11, 2010 What price range will these turbos be? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5491692 Share on other sites More sharing options...
hypergear Posted October 12, 2010 Author Share Posted October 12, 2010 If they test to work 100% you'll be looking to spending about $1900 to build in any of the brand new ATR43 units or around $1600 with Kai high flows. Also The high flow page has been updated. 2x New high flow profiles has been added. Standard high flow options using standard housings: 21U R33 turbo: 240rwkws OP6 R34 Turbo: 260rwkws Kai High flow using standard housings: 21U R33 turbo: 270rwkws OP6 R34 turbo: 290rwkws PU high flow using .82 rear housing: 21U / OP6 turbo: 300rwkws Detailed information is at our website: http://www.digi-hardware.com/rb25t3hiflow.html Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5491988 Share on other sites More sharing options...
l0WRB Posted October 12, 2010 Share Posted October 12, 2010 looks good stao,but wow the prices r gettin really high 4 a custom built turbo? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5492027 Share on other sites More sharing options...
zebra Posted October 12, 2010 Share Posted October 12, 2010 Can pay less for a genuine Garrett turbo and around half that for a genuine MHI turbo as well. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5492041 Share on other sites More sharing options...
l0WRB Posted October 12, 2010 Share Posted October 12, 2010 maybe these are becoming a little bit more expensive because they are bolt on items ( i think ) ? but u are correct u can buy garrett items for far less but these are not bolt on i guess Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5492060 Share on other sites More sharing options...
zebra Posted October 12, 2010 Share Posted October 12, 2010 They require 90% of the same mods that a Garrett turbo does, (oil/water lines etc) only real advantage is the standard style dump pipe bolts up. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5492065 Share on other sites More sharing options...
bozodos Posted October 12, 2010 Share Posted October 12, 2010 Isn't the main appeal that they look standard and are yes standard fitment as well? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5492071 Share on other sites More sharing options...
Rolls Posted October 12, 2010 Share Posted October 12, 2010 looks good stao,but wow the prices r gettin really high 4 a custom built turbo? GCG charge about the same for a bb highflow, I wouldnt say it is high for what you are getting. Can pay less for a genuine Garrett turbo I really doubt this. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/51/#findComment-5492094 Share on other sites More sharing options...
