sargerx8, fk thats a good result so far!!!
keen to hit you up on the offer of taking me for a spin and you can come in mine after to see the difference.
I will miss the induction of my twins tho lol
Ive replied to your PM.
Cheers
Cheers
Report all found!
Why only 11psi ?
The actuator we got is too soft, even with my EBC set to 100% the most we could get out of it was peaking 11.5 - 12psi... The fuel pump was failing giving some iffy a/f ratios so the whole tune is alot richer than it should be just to keep things safe, Ive got the fuel pump sorted out, just need a 12 - 14psi actuator and Ill go back in for a tune touch up.
It appears he's got fuel pump issues from previous reply.
Yeah, the pump was on its way out, it failed on the second day after I got the car home lean popping all over the place. Its got a GTR pump in there and Ive got a brand new 040 as backup incase. Also the actuator we're using atm is only a 7psi actuator and the most we could get from it was 11.5 with ebc @100%
Cheers
We shall see how it fairs up :) Keep in mind what Ive said about the tune and what not, in a month or so I should be running it at full potential.
I have some Dyno updates on my ATR43 G2 with FNT upgrade.
My car for those who don't know
R34 GTT with unopened RB25DET NEO
Turbo as above
All supporting mods
running Caltex E-Flex
This is NOT professionaly tuned, The timing is slightly retarded from before the FNT run. I just touched up the AFR's
It feels amazing on the street! f**king LOVE the powerband!!!
I have also added this to my running upgrade plot.
NOTE: The FNT run was done on a different Dyno with slightly retarded timing. So a true comparison cannot be made.
The FNT feels like it looks here on the plot. Heaps better down low and through the mid range.
I'm starting to think that my Blitz CS return flow intercooler could be posing a restriction. But f**k it... It's so good to drive as is :)
piss off Pat, making me contemplate ripping the turbo off again for some FNT goodness....lol
bloody nice results man, very impressed.
Apparently Stao has an even better housing for the G3 turbo, but based on results shown you would be mad not to.
Such good value, as always.
Thanks for the feedback. Comparing the ATR43SS pagethe FNT affects on above dynosheet is identical.
Its more then just the few hundred rpms better in response. It changes the car's driving ability making it lot quicker in acceleration from standing and gear change.
To Add FNT nozzle into G3 housings cost $200 including return shipping.
All ATR43xx and PU high flowed units produced from 1/1/11 has FNT nozzle permanently casted into the turbine housing delivering better driving ability while not affecting top end power.
Turbo as above
All supporting mods
That graph looks f**king sexy man, I love the straight line 280+rwkw all the way. I just wish I didn't listen to my tuner about 17psi being too high. Feels like I wasted so much money on a tune that I wont be staying on for very long :( I see almost 23 - 24psi going through your turbo. Are you controlling boost at all? I'm sure with a nicer tune and controlled boost you could make a little more power out of a little less boost too.
That would be from boost controller, I found this boost creep and drop behavior happens to customers with return flow coolers. check hary's result pre and after cooler tests:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__1640__p__5772487#entry5772487
Yeah looking at Harey's boost plot I'm even more sure it's the return flow intercooler restricting getting more power out...
But yeah it feels amazing, I'm not too concerned about getting any more out :)
Finally got my ATR43SS1 installed. After a short consideration I believe its totally worth paying $250 for one of stao's mechanics to install it onsite and buy what ever stao recommends from him self.
So I end up getting:
5x 2mm thick cooper washers: $20
1x hard 3 inch intake pipe made from 2x 45 degrees silicon hoses and 1x 45 degrees steel pipe: $80
1x hypergear's Blow off valve (Its massive, not a toy). modified and fitted onto my cooler piping. : $150
1x milled out brass plate blocking off my old BOV. $20
I've also bought an additional low pressure actuator for $100 installed for time been till the car is at a tuning stage.
His Mechanic showed up at 2pm yesterday and the whole thing was finished around 6pm. We went for a quick drive, felt good and no leaks. Paid the mechanic and called that a day.
Not really sure if the new turbo needed of running in, so I went for a 100KM trip today. This turbo is very responsive, on road response is about identical to my factory turbo, and it also a light "Singggggggg" sound on light throttle.
Performance wise, the ATR43 has a very strong take off. For example at take off at traffic light in 1st, 2nd, 3rd gear full throttle. The car would just launch, the power delivery is very linear from the first moment, and pulled harder and harder as it emerges red line. Like a smooth momentum with very strong and solid build up of power as engine revs out.
Drivability wise it's still very factory, with more power through out the whole rev range. My standard turbo in comparison just felt really flat after 4000RPMs.
The car's running about 9.5psi at moment on stock tune. Still waiting for few bits and pieces and I will post up my result once its fully tuned.
Money wise I spent on the turbo and installation plus hard intake pipe and custom bov fully installed so far is: $1970
The amount of time taken to install was bit over 4 hours including removing my factory turbo.
This is a brilliant turbo for a daily driver. Big thanks to Stao on the turbo plus the technical and mechanical support. Very happy . :cheers:
Edited by petero'nell
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
