If it truly has full boost at 3k I really doubt it'll make over 250kw
garret who have far more engineering experience can't even make a turbo that does that, sorry to be negative but I just can't see it being true.
See turbochargers engineered in this project are solely for RB25det engines, Garrett would make a turbo to suit a variety of engines. There are room for improvement when designs becomes specialized.
At moment it feels like some where around the 280rwkws mark with very steady torque. Its drives very differently to any other turbos I've engineered or experienced so far. I'm expecting an out standing result.
If this turbo makes 280kw with full boost at 3k I will buy one in the near future, providing it holds the power to at least 6k on less than or equal to 20psi.
This will be a garret killer if it makes those results!
my current highflow makes full boost at ~3k but only makes 240kw on 18psi, so if I can get 40kw over that with the same response, holy shit!
What are the main engineering differences with this turbo over previous designs ?
Edited by Rolls
Always watching Stao's progress, keep up the good work mate.
full boost at 3k and 280rwkw+ may be possible as thats exactly what I have now... just with a Garrett stamp and a slightly higher price tag.
Dyno sheet please
NA + turbo does not count.
Nope - nothing special, no E85.
tuner said not much difference between what he has seen with normal turbo motor and the slightly higher compression NA with my turbo.
post-36975-0-79536600-1311255089_thumb.jpg this was with an electronic boost controller
post-36975-0-72596700-1311255208_thumb.jpg this was with a bleed valve
Decent power for the street, very useable... as soon as I touch the accelerator I get boost..
What turbo?
edit: just saw your post, how on earth do you get a GT3076 on boost by 3k? Most people are seeing 3.5 to 4k ? Was that with some ridiculous ramp rate?
Edited by Rolls
What turbo?
The two runs are not equal... There must be some decent load and hold time on the EBC run as it starts at 9psi at about 2500rpm. A normal dyno run should start at around atmospheric pressure.
Second graph looks much more genuine with 18psi at 3500rpm which is pretty much what is expected from a GT3076R with a 0.63 :)
Edited by SimonR32
Its a good result :thumbsup: , high comp engine with adjustable cam gears would make a turbo spool earlier. Plus different dynos with different sittings would read differently. Compare to one of my earlier runs using the same dyno:
RB25DE high comp, adj cam gear, 3076 .63 ext gate, with a bleed valve
Standard RB25DET motor, stock head, ATR43G3 int gate, with Bleed valve. My run ended early due to misfire while still making 294rwkws.
They looks similar in terms of Power VS Response VS KM/H. But I know the SS-1 PU is more responsive. :yes:
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
