whats the optimum bosst level of the ATR43SSPU turbo people are running. i have a 15PSI actuator and will use this as the low setting in my dual stage boost controller but am unsure about the high setting. looking back in this thread I seem to notice between 21-25 PSi.
Does this seem right?
What are you guys that have this turbo running?
Cheers ,
Darren
Cheers ,
Darren
Ive got the ATR43SS2 I run my actuator boost as low which is about 13 - 15psi(its not consistant lol) and high boost on 17 - 19psi, again not consistant. I don't know, these actuators will boost and hold fine a few times, other times they just won't hit the target. Raising my boost controller will see 20+psi. Tao said this turbo created great power with minimal wheelspin.... At these settings, I have no traction in first or second. I tried to fang it up a bridge, i was ice skating 1st, 2nd and 3rd lol.
Sarge,
ATR32sspu was installed on saturday with 3 inch hard pipe made from Scotty-nm35 (great job of the intake mind you) and the car is presently being tuned today after z32afm & 660 injectors being installed.
So I am itching to take it for a spin and hoping to have a high / low setings with the boost 15PSI actuator for low and somewhere arouns 20-21PSI with high I hope...
Darren
Learn how to drive with your right foot. or put a brick under the aceleration paddle or some thing. lol
Suspension needs to be looked at.
Get it on the dyno and keep turning the boost up until you either make the power you want to, or you stop making power and obviously tune to suit.
New tyres, get some federal 595 rs-r or kumho ku-36 they are usually good value for money.
Edited by Rolls
@ Tao's post #2385 on pg 120.
Not a bad result there. Looks similar to a T67 dyno sheet, full boost around 4000rpm and nice flat torque from there to redline (just under 500Nm). Although wasnt this turbo a bit more responsive on the standard manifold?
Geeze external wastegates have nice boost control, just perfectly flat.
Very interested in the next stage.
Yea true. I have feeling this new ebay manifold is actually a worse performer then factory manifold. I've noticed the colour of the collector below the T3 flange went bright yellowish while the rest is in dall orange. The turbine housing just start to glow till about 22psi.
By colour code if I read it right its about 1000 degrees at that point of the collector. The stock manifold also glows, but lot more evenly.
Dammit I really don't want to change my tires again at the back, Ive got brand new tires there. I need two new front tires though so Ill probably chuck some KU36 tires up there. Ive got bilstein shocks with standard springs on the rear so it does squat and not too hard so should have some traction. I drive like a bitch most of the time so maybe my tires were still cold. If I should be using my right foot to control boost, why did I fit a boost controller and a whole setup to control boost. I can flat foot it one day and hit no more than 16psi. Flat foot it the next and hit 19psi. Just today I was driving down heathcote road and low boost crept to 15.5psi. Felt sweet though.
Maybe the metal around the collector is too thin and thus getting hotter?
What sort of tyres do you have on the back?
Personally I wouldnt run KU36s on the front for a street car. How often are you cornering or braking at the limit of traction? I hope not too often. I just run all round type tyres on the front that will last. Then I just keep changing the rears with nice sticky rubber that only lasts 10-15,000km. I find that a good compromise for the street. Completely different for the track.
Yeah actually after reading it seems the KU36 aren't too flash in the rain, and being a RWD the front does most of the control work in the rain. Right now Ive got continentals up front but they are starting to get old and dry. My rears I'm running forceum or some shit. They have a really deep wells, the rubber isn't too hard and they aren't so grooved and cut up so have alot of surface area to maintain contact with the road... It could be something up with my suspension, when I am taking off in first, I get alot of shudder and it feels like my arse is bouncing. I don't know how much the front suspension affects the rear but my rear is softer than my front(My fronts are teins which feel like driving on bricks). Too much shit to change, not enough money.
I can vouch for sarge driving like a pussy :D
Sorry sarge.
U need some subframe lock spacers to help with the tramping issue's.
So who is next on the hypergear performance tune? Waiting on some more results
Sorry sarge.
I will be soon after Stao is finished making my SS-2 :)
Nice... Did u call me the other day about this turbo?
Im curious to see how other people go with them.
Im still waiting for dynafit to post his dyno sheet of the ss1.5
By 'not too flash in the rain' they certainly arent as good as when hot, but they are still better than most street tyres! Comparitively when cold they are still good performers, it is they are just much better when hot.
I've got federal 595 rs-r on the front of my street car, not amazing when cold but all you need is one corner and they stick great, a few corners in the hills and they are amazing.
if you want something more progressive when cold get federal 595 evo, absolutely f**k all from opion1 garage, in fact ku36s are cheaper from option one than a lot of rubbish tyres youll get from local distributors.
Sorry sarge.
I drop my car off tomorrow, atr43 ss-1
My KU36s when a bit worn were quite bad in the wet, certainly worse then a standard decent road tyre. The worst part is that it wasnt progressive and just broke loose on me a couple of times.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
