This is the new SS2 prototype trail using the external gate turbine housing. It actually made about 300rpms better in response. how ever didn't help when the car caught in fire. lol. One of the rubber hose expanded under pressure and torched on the exhaust manifold. Well, made 293rwkws when fire broke out. lol. Will do a bit more trailing in later stages.
looks very nice @ only 20psi too
Impressive, how is the heat with this one, could you drive it for 10 minutes in the hills flogging it non stop at ~4k on full boost without it starting to detonate or lose power?
Also what is with the torque dip when it hits full boost, lots of your dyno graphs seem to have this, is there any reason?
Edited by Rolls
This one is pretty alright. Wasn't getting very hot. Turbo was ok. We didn't get too many runs as the rubber hose caught on fire. Floged it this morning with all the rubber hoses replaced and its so much fun with external gate.
not getting hot...but vacuum lines caught fire?
this thread can bring the lulz at times
If a rubber vacuum line touched a stock dump running stock boost it would probably catch fire.
It's probably not very important to some, but for what it's worth I flogged my car for three days straight at Powercruise this weekend and it loved it. Not a single issue at all, and the performance of the G2 was great. Didn't get too hot, just kept going all weekend.
Stao, I'll be watching this thread closely. Keen on an externally gated turbo capable of 300rwkw that doesn't lose too much response without having to change too much of the stock setup. Going to look into water/meth injection to keep things cool. The turbo you're working on at the moment sounds like it could be the perfect fit.
awesome! what turbo is he running?
That was a old TR44 turbo. They are the ancestors for the current ATR43G3. I still have few housings and wheels for those used as door stoppers at moment. Can put them together for $450 with 12 month warranty for any one whom wants one. Externally gated only.
Also some winton drifting footage from Abe's car. It made 290rwkws using the old ATR43G3 none FNT version.
Its currently making 347rwkws with the FNT update on E85. Should be seeing him hitting the track soon.
Edit / add:
The youtube quality sucks, you can down low the raw footages from links below:
Door mounted camera
http://www.digi-hardware.com/photos/abphotos/sidecam.wmv
Roof mounted camera
http://www.digi-hardware.com/photos/abphotos/topcam.wmv
That is enough evidence for me.
Agreed on the too many turbos thing zebra.
Something like this would be fantastic
turbo name, specs @ x psi, peak kw, peak nm, peak torque -25% from x-y rpm (eg 3500-6500rpm), cost, internal/external gate/housing type
Edited by Rolls
Stao - Can we get a run down of all the products you currently offer....Ive tried looking back through this thread but info is all over the place
Pretty much what ever you see on our website. Here is a mixed of older, current and under development products. Once a better product is developed, the older version of it is automatically discontinued and replaced. Just like the ATR43G3s built in 2008 is a completely different turbo to what it is today.
The Youtube video quality is so bad compare to my original footage, I’m seeing many familiar cars. Yours might be in the footage. I will post an http link once they are uploaded.
Is it possible to compile something like what I said stao? I saw that you put quite a bit of effort into overlaying all your graphs in the past, would most likely be less work to do this. :)
Could we get some footage of you flattening the throttle at 2k in 3rd gear until like 6k or something? I'f you could film the tacho that would be fantastic, love to get an idea of the transient response on the road. :)
Ill get this footage tomorrow. Ill try to push it as far as I can. Did anyone notice the XR6 lol.Tailgated me a fair way waiting for me to run him.
Edited by SargeRX8
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
