Hey guys
Will it do any damage or cause any trouble if I put the SS1PU on without the nistune installed yet?
Trying to work out a way I can get the car to DVS without having to tow it up there.
I was thinking install the SS1PU and then get my brother to wire up a plug for my z32 so I can drive up with the stock AFM then just chuck the Z32 when I get there
how far are you going to be driving, isn't DVS a couple hours away?
It's very possible not to boost lol. If you want to install the turbo before you get it tuned then you don't boost it, simple.
On the stock ecu it will hardly boost before it hits r&r anyway.
I ran my ATR43G3 for a year without being tunned ran it on 7 psi and its ran great just laggy.
Loosen off the actuator so its sloppy comming on boost and you will be fine hitting up to 5 psi on stock tune
Possibly get a base tune by someone in Canberra and let the turbo run in, then go to DVS to get the tune tweaked?
If money is a factor, work out if it'll more $$$ to tow 4 hours or get a base tune here and drive up.
Hey guys
You will be fine. If the turbo is the only aftermarket thing you've got on there, it will be fine. 4 hours of tow truck.... gonna cost you. You can easily drive the full speed limits. Going up to his place is pretty easy, no pressure to floor it or go fast. Once you are on the free way cruise it there. Get all the prep work done before hand(as you are with the wiring) so when you get there and get to the dyno, minimal time is wasted dicking around.
I drove my car to my tuner about 20 minutes away first time. I had all my aftermarket parts in there except my injectors(didn't want to risk the wrong settings). It was running on the base tune with the z32 afm and it was fine. This drive was through start and stop traffic.
I can probably drive my car to the other side of australia at 110km/h without hitting any boost at all. Right foot, control and toot on. You won't hit 6psi unless you actually tried to. You'll be fine man trust me. You will get there faster than a tow truck will and you will have the money in your pocket to pay for the tune or pay for something else when the car isn't making the power it should.
Yeah he is at least 4 and a half hours away which is impossible not to boost
What kind of issues does it cause upgrading from stock turbo with the stock ecu.
Thanks guys
If you boost it you risk detonation, however what you can do is leave the wastegate actuator off so you literally can't boost more than 1-2psi by redline, do this.
ive been driving with my gtx3076 and stockish tune, cant do more than 2-3psi without the engine light coming on, you should be able to baby it around no probs
just change gear at 2500rpm with not much throttle, mine still keeps up with traffic even off boost, just shift up quickly and your fine.
taking the actuator off will make it sound very loud and drive like a dog, atleast thats what happened with mine.:whistling:
The turbo it self acts like a muffler of some sort, bypassing the turbine the exhaust goes through the open wastegate, it will be louder. It will run like arse, but its foolproof and safe if you are worried about foot control.
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
