Just realized they said there was boost control issues so I guess that would be affecting power up top a fair bit as well.
If it was holding boost to redline I still think itd be 250+
I wouldn't expect it to be hitting 270kw on 20 psi with a 15+ yr old motor.
Edited by Mitcho_7
Wait for the charts gentlemen, no point speculating over power figures or what's responsible for them until we see what the engine is doing. As JEZ said, there's probably a bit more in the turbo if they take the time to sort out boost etc. but for now Kasko should be pretty happy and he looks to be.
Very smooth. Boost tapering off = another 10-20 if you can get it to hold without the engine pinging?
Full boost looks like high 3000's / 4000rpm, I'm guessing.
  • Like 1
Need ebc to hold boost up top. I'm testing a little mod this weekend and hopefully that changes the boost behavior up to.
Already got a profec b spec 2 installed in it
This didnt help with the tapper.
Seems the actuators are not up to holding the 20psi consistently
Also as DVS said it seems my clutch is either on its way out or needs a bit of adjusting/bleeding
The car feels phenomenal when it comes onto boost and spins 2nd without hesitation cruising.
Next step is a CAI and a box for the pod filter might help a little.
We did back to back power runs on a safer tune and only lost around 1-2kw
Is that same turbo you have birds?
Yeah man.
How bout that! :)
What size tyres you running?
Assuming it's 4.11 diff ratio and normalish sized tyres is nearly at full boost at 4000rpm with 180rwkw
Not exactly comparable with a GT-RS
180rwkw @ 4000rpm IS comparable to a GTRS, I agree.
Forget about where it hits full boost etc etc. The power @ RPM will tell you what its doing flow wise, which is what counts.
Every decent turbo makes 180-200rwkw at 4000rpm on a RB25... It can be a T67, 3071, 3076 or HKS 2835pros, they all do it
It's what happens before and after then that makes the turbos different!
Edited by SimonR32
Yeah, so doesnt a GTRS do roughly 180-200 @4000 and end up around 250 by 7000? LOL
So its more or less hitting GTRS benchmarks, OK glad we agree. :whistling:
If the turbo can hold boost for the upper RPM, there's no reason it can't make 260-270 IMO, so no it's not comparable to a GTRS...it's slightly better :P
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
