Guys,
How about starting another thread "For Clutches" as this is starting to hijack the Hypergear Turbo thread.....
Dont get me wrong (its all interesting as I will need one soon so i am whatching what is said) but its getting a little off topic for poor Stao & his fantastic turbo's....
Just a heads up ok dont want to put any nose's out of joint so to speak....
Dazza
If Stao has an issue with it I'm sure he'd say so. He indexes all the pages in this thread so it's not like it's difficult to find the sections relevant to your interests. I think this is a pretty important part of the turbo selection process as people should know what works with what. I like that the threads, both Kando and HG take a focus on helping people with their whole setups instead of just focusing in the turbos. We're like macro communities :)
Its good to have documentation from all range of supporting mods working with the turbo. I will index them in the main page.
I've been taken some time off working on my electric turbo again. lol here are some latest updates:
The new charger runs of 44V 120AMP of power from a 2x 6S power source with RPM controller.
I've installed it on to a Daihatsu Sirion with a 3cyc 0.97L engine. This car makes from 0 to 100KMs in 21secs factory. lol
After appling the charger in 3rd gear full throttle it actually made the Speedo rising a tinny bit faster. There is a just noticeably acceleration gain with the charger is activated and not. I'm installing it on the R33 for dyno runs next weekend. hopefully making better result then the previous one.
Plus I'm working on a VNT .82 rear housing for the G3s hopefully getting SS1PU's response with 330rwkws top end.
Can this new VNT housing be made for external gate? I just purchased a wastegate and highmount so as discussed a month or so ago my turbo will be comming back to you soon.
Will try and get it off this weekend
Trying to decide if i should send you guys my stock rb25 turbo or buy one off you or buy a GTX30/76, chasing 400-450hp, what would you sell me? i would like too stick too Australian products.
Edited by 51NNA
The limit for a Bolton G3 on a stock exhaust manifold would be 400rwhp with proper mods on pump 98, unless if you are going for E85 then you can get that 450rwhp+ (abe's R33 358rwkws).
Or you can high mount It run external gate, which would be the best solution for the goal, and reduces the cost in building the turbo to just $1000. We also have a externally gated turbo called the SS3. That would reach you goal with possibly the best response.
Pump 98 results and details from that turbo is in page 120
It was a billet wheeled turbo based in a SS2 externally gated housing. It was very responsive how ever only worked well externally gated, internal gated version was about 30kws short. Its a very different turbo to the G3, how ever you can run that rear housing with it and the results won't be far off.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
