Some updates:
I've finally managed to start the car, for some reason it was much harder to get the E85 started when the weather is cold. It is other wise in a worm day. unfortunately this years Melbourne winter is pretty cold.
It is often hard to start E85 in winter due to the lean mix of unleaded petrol. This is primarily why E70 exists and E-flex is supposed to have an enriched unleaded content during winter.
Some result from the new SS2, only had time to do a touch up on my E70 tune and my fuel pump is at its limit. I will need a bigger pump for the E70 to finish off the power run in couple of weeks time. For time been it made 345rwkws at 19psi bleeding down from 22psi. Likely there is another 15KWs gain using a high pressured actuator holding 20psi up top with more fuel. It is currently running the lever mode with a 14psi actuator.
For some reason the lighter material did not alter much in boost response on paper, how ever managed to produce heaps more mid range in comparison to the G2.5 that made similar power output. The difference is very noticeable on road, does not feel laggy at all.
The prediction on pump 98 would be around the 285~300rwkws mark as the capacity of the Type B .82 rear housing is up to the 300rwkws mark.
There was only enough time for a touch up today. I will do 98 run when I get the fuel pump replaced.
Here are some video footages taken from today. Note the difference in sound between the light weight billet comp wheel to the traditional cast and 7075 billet wheel. It came in very early, how ever on paper it doesn't show much.
thats not a bad result, its quite nice.. however that is on E70............. please retune on 98 to make it a usable reslt
Agreed. Looks mint but e85 is too hard for me to get.
Thanks for the offer Stao but I won't be sending mine back for the update. Will just bolt it up as is.
Thanks again
+1 ^^^
Where's the ethanol love? Usable result for who? Its Stao's car not yours Scott and he wants the powah. :P
It sounds like they all jelly Artz...
maybe he should re tune on 91 octane so it can be a good result for all the complete wankers out there lol.
should he run low boost aswell just incase ppl who buy one of these turbos dont want to run the boost he is testing on??
Edit. I won't say it in here. That wouldn't be fair on him with his potential future customers.
Edited by lilcrash
looks perfectly usable to me , now stop your sooking :P
+1 ^^^
Yeah, lets showcase how good a turbo runs on ethanol when 95% of the customer base is running 98.
:no:
:no:
I think you would be surprised, its not 95% mate, and there is a growing percentage switching over these days.
Stao is in Melbourne, half his customers down here are on ethanol or plan to run it. Just take 40kw off the graph if you need the 98 figures.
Ask Trent what percentage of his tunes are e85, I would guess at 30-40%. Get with the times... :)
All well and good to take off 40kw, but ethanol changes the whole curve. You would essentially be guessing at how the turbo would perform on 98, and I don't know about you but I wouldn't buy a turbo where I have to estimate how it's going to perform.
I think testing on ethanol is fine, and it is very interesting, but I still think Stao should get results on 98 as well, otherwise it makes diagnosing potential problems very difficult. I mean, we've seen how many people in this thread, including myself, have had substandard setups and not made the expected results. Stao has always been extremely helpful on this front, but what happens when customers start buying these turbos that have been tested on ethanol based on an estimation of how it will perform on 98 but then don't get the expected result? Is it a case of underestimating the effect that ethanol had, or are there other issues?
No point sooking about it. I want e85 results. :P
Do GCG or MTQ do any testing and post it up for all to see? How is it Stao's obligation?
Lol, not sooking, just discussing. It hardly matters to me, I've already got my turbo. That said, I did ditch my previous G2 based on the result of the G3 in here...
It's not. He isn't obligated to post any of his results, I'm not saying he is. I'm simply voicing my opinion as a previous Hypergear customer, it was the results in this thread that convinced me to buy one.
Its not his obligation, and i still applaud the mans work through and through, but that was my opinion.
VIC might be lucky (and full of fags :P) but NSW and WA are suffering without a reasonable ethanol supply at this stage.
Anyway lets not get into it. Believe me I WANT E85...... It would save me the rebuild im in the middle of right now.. But it aint happening quick enough to warrant letting my car sit around unused or half tuned for ages.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
