and to the person thinking of going z32 ecu nistune - i think change your ecu plans, FC or Link plugin. Nistune is great, and i highly recommend it... but for 33 owners, there are better options.
Theres always better options for anycar, but at what cost. There is no way to compete against the price of a Nistune.
U need to upgrade ur fuel system on most setups. So that cost is accounted for in both fuels. Plus using the gas analogy it is way better for saving money as the savings pay off the capital cost. And once that's done its pure savings
FC? that's cheap. How much is a Z32 Nistune setup? must be pretty close $ wise to a second hand FC?
They go for about $550 or so. Most places seem to do a drive in drive out install and tune package for $1100 which is about the cost of a second hand fc with a hand controller.
Mitch you and I should get this E85 shit happening.
Will my 555 injectors and walbro 255 pump handle E85 up to around 260-270rwkw?
Thats just a guess as to what the SS1PU can pump out when using E85
I reckon about 270kw, but I think bigger injectors would be a wise investment long term and to give you some safety. Im not sure if you're walbro is up to the task or not though to be honest. Just get a bigger one anyway so you dont have to worry about it and that way when you want a bigger turbo you wont need to update again!
Im not going to go the e85 route til theres more places in canberra that sell it...
Edited by Mitcho_7
You know there's a United with E85 at the top Old Bathurst Rd in East Blaxland now? That's only 6 or 7km out of Penrith
Surely the 'Riff will get one soon.
i didn't know this ... but this has me right on the verge of maybe doing it ... I'm up there 3 times a week for soccer anyway .... excitement!!!
It changed hands about a month ago & has 100 octane Premium and E85. ;)
Engine bay pics..... SS3EG
Still a little bit more to go before its all done.
You sir have a very nice engine bay
I followed your build and love the gold
If you don't mind me asking
How much to get the turbo done like that?
Thanks mate... it will look even better once its all finished..
Ive spent a fair bit on ceramic coating and anodizing.... about $1000 all up lol but its so addictive.
I think the turbo was about $200-$300 for the front and rear... I did the back black and the front gold, but there is a heap of different colors, the chrome stuff looks mad.
I got it also to control heat, apparently should reduce engine bay temps by up to 50% but I did it mainly to stop things melting if they got too close to the exhaust.
they coat the inside and the outside so its meant to stop some heat from ever getting to the metal..
Wow this is interesting.
Anyone know anything else on this
Such as proven results in reducing heat sink and allowing for bigger power gains?
Pretty sure that's the basic theory behind ceramic coating? It keeps more heat in the exhaust, more heat = more energy. Obviously keeping the energy in the system is better than having it dissipate out into the engine bay.
keeping heat inside the exhaust housing is a good thing, and coating the comp housing would probably effect very little so its all good.
very nice looking setup :)
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
