Just put hi-lighter over it. Forgive how rough it is etc.
Yellow is original 315 result
Blue is 307 ex gate
Green is new one with .82 rear
Maybe Stao can get proper comparison sheet when he try's next wheel
Thats with all of them running about 22psi yeh?
I think the new setup internally gated has the nicest curve
Didn't check boost actually But they are all final results so yeah around that. Too hard searching around on my phone to do it properly
But new one runs 82 housing not 63 so should be cooler on track. yet response is still on par.
Further updates. This is the 2nd SS2 prototype been trailed. More responsive and made more power to previous version. Internally gated.
Max of 312rwkws on BP 98 and 210rwkws by 4000RPMs
22psi by 3750RPMs, 20psi by 3650 RPMs:
U
Max of 348rwkws on E85, probably another 15kws in it as my fuel pump is out.
I believe this turbo would make a pretty responsive 250~280rwkws internally gated on a stock manifold on pump with around 18psi of boost. Would go crazy to run on external gate and e85.
The 5 bolt externally gated version is cheaper then the bolton internally gated version. That is $1100 The factory bolton version is $1375 and oil line is additional $88 which is required to complete the setup.
For any one whom's looking for the externally gated setup, I can supply brae auto's high mount manifold with any turbochargers, with $200 discount off total.
pretty good value..
Too late now. You already picked your side
Its never too late ;)
If I ever get done for my external gate prompting a rebuild, I would definately consider it, until then my car is fast and I am happy... :happy:
For any one whom's looking for the externally gated setup, I can supply brea auto's high mount manifold for $900 with any turbochargers, they are $1100 retail, so $200 off the total package.
50mm external gate is for $200.
Fark cheaper then the SS1PU
I thought external gates were ok as long as they are plumbed into the exhaust?
Or are you running a screamer pipe?
the breas are a side mount manifold yes, or do they do a top mount aswell?
Can you weld up something to run the external wastegate off the underside of the rear housing (and plum back into the exhaust futher down) rather than having to buy a new manifold or does that not really work that well?
It can be done, gain is more significant if the external gate is fitted on to the exhaust manifold.
Stao, in your eyes, what would work best if you had 2 options with the ss2, a internal gate ss2 on a brea manifold..or a external
gate ss2 with ext gate put on stock manifold?
cheers
darren
Obviously Externally gated setup would pickup more power. There should be 20kws gain running external gate on my current setup.
well I wasn't sure it was so obvious, you said you picked up 15rwkw going from Brea from standard mani ..so i would have thought
the gains from standard manifold to ext gate might have only closed that sort of figure in..guess its one of those things you(not you, but someone)
really have to back to back...
cheers
darren
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
