You got da high comp bro and you worried about response?
I don't see any other option for you... You can deny it as much as you want but I can see you filling at caltex within the year. lol.
lol when caltex roll it out across the state ill be using it for sure. at the moment theres nothing local to me which supplies it.
if the car ran out of fuel its like hey lets go for a half hour drive with a jerry can lol about half an hour in only 2 directions. much further in any other :(
the high comp is due to retire soon. DET block has been bored 20thou and CP pistons at 8.5:1 have been match bored already. crank is next (once i pay for some dental), will match some bearings to it and check the rods. put it back together shortly after and grabing a 20g to go.
plan is to pick up some detchwerks 1000ccs while im at it so im ready for the good stuff when its actually available ;) keep in mind my car is intended as a frequent driver and track car. the only ameture friendly track is over 2 hours drive away and i havent seen a caltex there let alone any eflex supply lol. but sooner or later ill join you guys on that bandwagon, yes.
This is very true but 2nd gear is snapping into 3rd is my fav!
It steps out out when ever you plant it in 2nd.
Have you fixed your clutch slip?
My tyres hold strong in 2nd, it's the clutch that let's go when the power comes on! Meant to have clutch in the other day...but we had a customer warranty job to fix, so my car should be on the hoist tomorrow hopefully!
S1 R33
3 inch dump,high flow cat, 3 inch exhaust
Apexi metal intake pipe with pod --- problem?
China fmic --- problem?
044 fuel pump
660cc high flow injectors
Superspark coils with copper plugs @.8
Nistune ecu
Eboost street
SS1pu
277.0hp @17psi
There isn't any boost leaks, we checked while there. I also double clamped all the pipes to make doubly sure.
I did check at the time whether i pulled all the rags out as well.
It's got me stumped, any ideas??
Encouraging news.
Replaced the cat with a 100cell 5inch body metal cat (forget the brand,venom?)
Plazmaman FMIC with a turbosmart fully recirc BOV
3 inch metal intake (thanks to Scotty)
I put a nistune map on that Stao gave me and it's boost waaaaay earlier, only put the map on for a trial. It coughs its guts up any higher than 3000rpm but i did see 10psi at quarter to half throttle by then.
I've put the Hyperdrive map back on until i get it to the dyno again.
Next problem is, do i take it back to Hyperdrive or Pzp? or even post it off to Toshi?
Wish i could take it over East, sounds like theres some great tuners over there.
Anyone know of anyone else in Perth that tunes r33 with z32 ecu?
Cheers
Encouraging news.
Cheers
Preferably Allstar in WA, Just get them do a check up and some patch up if required.
So this is what happens after 400-500 launches, several DECA/skidpan days and 3 years of daily driving. It is was a cushion button, so there's supposed to be organic lining between them fancy paddles...which have about half a mm left in them. Note also the heat spots on the cover plate. All in all a solid effort from the Exedy, as she was still letting me launch hard until the very end, only giving out under too much boost (SS1PU POWAAA) and I think that was clamping pressure related. Would definitely use this clutch again if I wasn't making too much power for it.
Waiting for my flywheel (read: saucepan) to come back from being machined and then the NPC organic + reco gearbox go in. <2 hours work so far, not bad for a gearbox and clutch change.
I raise you my button clutch, I did this just daily driving the thing ; ) Totally destroyed it, you can see the heat discolouration and warping of the rivets, with only 150rwkw as well lol.
Edited by Rolls
You know, you're not supposed to be proud of destroying it that easily :P
Was yours cushion button or button? Looks to have the buttons of a cushion, but your sprung centre is different to mine?
cushion apparently, but it was TERRIBLE to drive, shuddered and f**ked my gearbox, in the end it still had massive bite and shudder but would slip on hard changes to 2nd.
I am renowned for having no mechanical sympathy haha.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
