You got da high comp bro and you worried about response?
I don't see any other option for you... You can deny it as much as you want but I can see you filling at caltex within the year. lol.
lol when caltex roll it out across the state ill be using it for sure. at the moment theres nothing local to me which supplies it.
if the car ran out of fuel its like hey lets go for a half hour drive with a jerry can lol about half an hour in only 2 directions. much further in any other :(
the high comp is due to retire soon. DET block has been bored 20thou and CP pistons at 8.5:1 have been match bored already. crank is next (once i pay for some dental), will match some bearings to it and check the rods. put it back together shortly after and grabing a 20g to go.
plan is to pick up some detchwerks 1000ccs while im at it so im ready for the good stuff when its actually available ;) keep in mind my car is intended as a frequent driver and track car. the only ameture friendly track is over 2 hours drive away and i havent seen a caltex there let alone any eflex supply lol. but sooner or later ill join you guys on that bandwagon, yes.
This is very true but 2nd gear is snapping into 3rd is my fav!
It steps out out when ever you plant it in 2nd.
Have you fixed your clutch slip?
My tyres hold strong in 2nd, it's the clutch that let's go when the power comes on! Meant to have clutch in the other day...but we had a customer warranty job to fix, so my car should be on the hoist tomorrow hopefully!
S1 R33
3 inch dump,high flow cat, 3 inch exhaust
Apexi metal intake pipe with pod --- problem?
China fmic --- problem?
044 fuel pump
660cc high flow injectors
Superspark coils with copper plugs @.8
Nistune ecu
Eboost street
SS1pu
277.0hp @17psi
There isn't any boost leaks, we checked while there. I also double clamped all the pipes to make doubly sure.
I did check at the time whether i pulled all the rags out as well.
It's got me stumped, any ideas??
Encouraging news.
Replaced the cat with a 100cell 5inch body metal cat (forget the brand,venom?)
Plazmaman FMIC with a turbosmart fully recirc BOV
3 inch metal intake (thanks to Scotty)
I put a nistune map on that Stao gave me and it's boost waaaaay earlier, only put the map on for a trial. It coughs its guts up any higher than 3000rpm but i did see 10psi at quarter to half throttle by then.
I've put the Hyperdrive map back on until i get it to the dyno again.
Next problem is, do i take it back to Hyperdrive or Pzp? or even post it off to Toshi?
Wish i could take it over East, sounds like theres some great tuners over there.
Anyone know of anyone else in Perth that tunes r33 with z32 ecu?
Cheers
Encouraging news.
Cheers
Preferably Allstar in WA, Just get them do a check up and some patch up if required.
So this is what happens after 400-500 launches, several DECA/skidpan days and 3 years of daily driving. It is was a cushion button, so there's supposed to be organic lining between them fancy paddles...which have about half a mm left in them. Note also the heat spots on the cover plate. All in all a solid effort from the Exedy, as she was still letting me launch hard until the very end, only giving out under too much boost (SS1PU POWAAA) and I think that was clamping pressure related. Would definitely use this clutch again if I wasn't making too much power for it.
Waiting for my flywheel (read: saucepan) to come back from being machined and then the NPC organic + reco gearbox go in. <2 hours work so far, not bad for a gearbox and clutch change.
I raise you my button clutch, I did this just daily driving the thing ; ) Totally destroyed it, you can see the heat discolouration and warping of the rivets, with only 150rwkw as well lol.
Edited by Rolls
You know, you're not supposed to be proud of destroying it that easily :P
Was yours cushion button or button? Looks to have the buttons of a cushion, but your sprung centre is different to mine?
cushion apparently, but it was TERRIBLE to drive, shuddered and f**ked my gearbox, in the end it still had massive bite and shudder but would slip on hard changes to 2nd.
I am renowned for having no mechanical sympathy haha.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
