Does look clean..dont think I have seen a yellow one before...
Should look clean, everything went through the acid bath or sandblaster at work. Respraying yours yellow now?
Prob Just a pod. Haven't bought hoses yet to fit inlet. Dummy fitting crossover pipe now to check recirc hose fitment. I'll take pics as I go scotty. Also dump pipe fouls on a/c drain so will double heat wrap dump pipe at that section and maybe remove outer black tube.
Made any heat shields for these Scott? Could pick up off top 2 dump pipe bolts easily. Might have a crack at something once it's going
Since my car's off the road, I've managed getting Brae to have my existing manifold modified for an 50mm external wast gate.
We are also in the process of making an simpler exhaust manifold that is in factory style with larger inner diameter made to support an 50mm external gate (or can be left internally gated) at a very affordable price. It should be a bolt on item to factory setup, and holding the turbocharger in factory position. It is designed for for the ATR43 bolt on series or any standard bolt on high flows, I will have that trailed when it becomes first available.
Don't like lobster alloy pipes? Sorry if it isn't pretty enough for you. :P
The inside is dead smooth, it will make the power, with no bov reversion. Can you post a pic of your design?
Yeh but it doesn't say Greddy and you can't see yourself in the polished reflection.
I make practical intakes that work, not fap toys. lol.
Exactly my thoughts mate, your product is proven to work, is good value for money and I cant wait to get one installed on my ride :)
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
