Was just being a dickhead, ofcourse if you're going from a stock turbo and catback to a HG then no shit sherlock.
Going out on a limb i would say most potential buyers would already have upgraded the dump pipe.
My point was Stao tries to make these turbo's as easy as possible for people to bolt on themselves, without having to worry about buying/fabbing up other things to get it to work.
It was the reason i bought one instead of a GT3076R kit.
Now that we know that JJR quality has gone down hill for the 1 piece dumps all we need to do is find an alternative. My money is on the Xforce.
Mine would be 7 or 8 yrs old. While its probably not as bad as others that are more recent(possibly is), it still didn't match properly and I tapered the edge in places to make it better.
mmm well looks like I really have to make the dump pipe my self to get every thing properly. I'm thinking of getting rid of the factory 6 bolt patterned dump, and have a 38mm internal gate assembly made from scratch to a proper 3inch Vband dump, then a 3.5inches turbo to cat front pipe.
38mm internal wastegate:
The internal wastegate assembly:
Final assembly:
Looks good doesn't it. The cost of making above including a proper one piece dump n front pipe costs $475. Works out to be $1375 for the Gx series. Still pretty cheap considering what most people paying for dump pipes this days. I will post photos as the kit completes.
That looks great Stao,
how long do you intend to make the dump? Similar to bell mouth obviously if its going to the cat?
This is setup for ss2?
That would fit any of the 60mm wheels Id say. G2/2.5/3/SS2
My point about the JJR dumps is not so much that they have suddenly became crap, but that we should find an alternative so that people can continue their love affair with the bolt on HG
Trev, I'll keep you informed mate. Going back to Kermy in the next couple of weeks to get my screamer redone, so I'll ask him what he thinks of it then.
Sweet, I imagine Stao will have results on this by the time I'm home so should be able to make a decision either way. I need to do exhaust ASAP cos its way loud. I've been pushing it out of the garage in the mornings and start up while im rolling down the driveway for a quick getaway.
Haha yeh tell me about it. I have to jump start it this morning (fkn left bonnet open and forgot to switch interior light off. Means at least a minute of terrorising the neighbours lol. But I love the sound so they can deal with it :F
My mate has fixed up the JJR Dump. Probably now about 75% better. Will post pics when I get the chance
Some of the walls where getting really thin so limited our ability to match it 100% with the gasket
Yeh this is my issue with cleaning it up which has me considering just getting one made.
Would be curious at the potential loss of power
if its negligible and like 5rwkw then I wouldn't worry about it
but its say 20rwkw then might be worthwhile
Stao's already talked about it in earlier pages that the internal gate will never open to 90 degrees. so the gas can never hit a 90 degrees wall. What I can see he's done is by making a huge wastegate flapper it needed more room for it to open there for needed that extra round bit of space.
Like I said, will be interesting to see the results. The flap can open however it likes, exhaust flow is has to turn 90deg out of the wastegate orifice cast into the housing and then again as it merges with the flow of the exhaust gas.
If he has the sizing sorted then will be a nice solution.
And re the more power/boost less exhaust flow...true but the problem is compounded as you also have more mass of airflow through the engine which needs to go through an orifice in the exhaust housing scroll the size of a 10c piece and when the gate opens another 20c piece which when it opens has to merge without causing turbulence and back pressure to all that exhaust flow through the turbine.
I sure as shit have no idea how it all does what it does so well...just have seen for years people try to get the same result as my setup out of the internal gate TD06 turbos and fail, only for those to go external gate setup and the things work so much better.
tbh for flow, boost control, exhaust restriction, an external gate is superior.. but comes a cost associated with the gate itself and fabrication.
Yeh well I wouldn't expect it to be a hell of a lot, but considering I'm chasing a restriction in my setup somewhere, I just want to know that everything is as good as it can be.
Roy my understanding is that in an internal gate turbo the main exhaust stream from the turbine actually sucks the gas from the WG flapper.
So in this case its still possible that the design will still work, and pending results it may work well.
As proven in the kando thread, that specific shitty housing was still shitty with its arse lopped off to operate like a normal 5 bolt rear. So its not necessarily the WG design that makes it shitty, but just that housing in general.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
