Thanks guys.... haven't posted results yet because I dont have any.
Me and Toshi did the road tune, but we only got to 16 psi and then we noticed it was missing..
Fixed the miss and then noticed a few air leaks which I have now fixed.
Now Ive just gotta sort out a boost controller as my EVC isnt working and then Im good to do a proper dyno tune...
Cant wait to see what it puts out as its pretty wild atm and its only on 16psi.
Frys tyres when it hits boost in 1st, 2nd and 3rd.
Going to turn it up to 20psi and see what happens.
20psi? why stop there? lol
keep boosting till you find where it stops making power. tis what I will be doing with my SR SS1PU
On the SS series where people get big boost drops, is it worth trying the Gizzmo IBC-R EBC so you can set the gains
higher as rev rise to try counteract the drop in boost, or has anyone tried one and doesnt work ?, are they any good?
cheers
darren
Edited by jet_r31
You need a strong actuator, but it needs to be installed after tuning preferably, (tuners don't like running it up on 20psi or more off the bat.) Once you have the stiff spring the electronic controller may have a chance of holding boost flat.
On the SS series plus other G series, they got updated wastegate setup now. The boost drop on those at about 20psi is around 2psi. If any one's got a huge 6~7psi drop then that has nothing to do with the actuator setup. It means its got some sort of restrictions more likely on the cold side. could be intake pipe, small cooler or blocked/bad/small piping.
You will find that by tabbing a boost gauge straight after the turbocharger and inside the plenum. If there are big differences then that is the problem. I'm seeing this often with return flow and some cheap ebay cooler kits. Reference is in page 83.
Some further updates on building the TD06/67 test rig. Car is now fitted with a Brae high mount manifold with our own 50mm external gate plumbed back with a 4inch exhaust exhaust.
Looks good. It did not come with a cheap price. All including the exhaust manifold, screamer, dump pipe plus installation comes to $1880 plus $250 for the external gate, including the turbocharger this kit comes to: $3230
How ever there is a very noticeable gain in mid top end torque without noticing the lose of response.
I will use this test rig to trail all the TDxx as well as the existing ATR43 turbochargers. This setup should provide the best possibly environment for the performance of any turbochargers, and is whats expected on a welly built track car. The end results will vary if components of the setup is differ.
Externally gated turbochargers are cheaper to produce.
Looks good. How ever it did not come with a cheap price. All including the exhaust manifold, screamer, dump pipe plus installation comes to $1880 plus $250 for the external gate, including the turbocharger this kit comes to: $3230
haha dont push it too hard till its tuned :P ecu is map sensor based remember :P
hooo crap. I was red lining it 5th gear and my speedo pointed at 10km/H. Its still using the same turbocharger, external gate was holding pretty flat 20psi, in theory the exhaust side should be cooler compare to stock manifold, I didn't hear any knock, hopefully engine's alright. Or will be rebuilding it again for 2013.
Yes I was sitting in a hoist :P
This is my first batch of 25G billet compressor wheels. I've customized the wheel hub and fitted much larger blade with taller profile. I'm hopping to peek around 400rwkws on stock cams before hitting 7000RPMs on E85.
So dimension wise, do the T67's fit on the stock manifold with a spacer if you have one laying around there?
Are the comp covers any bigger than 3540 .70's ?
(and yeh i know you will say it makes to much power for stock mani, but thats not my question..lol)
cheers
darren
If ron can fit a 5558 between the strut tower with a 12mm spacer im sure the T67 will fit too.
Im confident the comp cover will be similar in size to stao's .70 or a T04Z/precision etc. No issue there.
The issue is more so that the exhaust housing flange will be a different distance from the centre point of the CHRA. Realistically it makes no difference how much spacer plate you use provided that the comp housing clears the exhaust manifold.
It's a large housing, not sure it will fit on the stock manifold...
thats all anyone ever writes..lol, (not being rude) but 3540's fit on stockers, surely it can't be to much larger(if any)
be nice to know exactly by someone that actually had both for once, so its not misinformation.
Not thinking stocker mani, be interesting if it fitted on a BREA or NZ style sidemount
the 5558 would be .60 3076 in size would it not?(thats what it looks like in pics) , bit smaller than the .70's
cheers
darren
Edited by jet_r31
Hey Stao, I'm still digging the development your pooring into your products..... AND freely sharing the info.
I'm hoping you have a little something in your bag of tricks that can help me..
I drive a S2 (rb25 neo) stagea as a daily... usual mods (fmic, full 3" exhaust, nistune, fuel pump etc...) Do you have a bolt in turbo option/combination that will come on power earlier than the standard turbo? But still make the same or more power. Essentially making it feel like a bigger engine.
I'd like to cap the boost around 18psi
Cheers
Justin
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
