My turbo turned up while I was away at work, didn't even know it was on the way :P
Thanks Stao for all the help you've given me through this process, turbo looks good and can't wait to see how it goes. Now just have to finish my engine
I only have the standard highflow which is good for 430hp.
270x1.34= 361rwhp
361*1.2=434 engine hp allowing 20% drive train loss (which is a widely accepted rough estimate)
Yours sounds about right,
Is that v-band???
V-band rear? yes
3.5" V-band
I will take some more photos in a minute, that was just a quick camera phone photo last night when I got home from work
Very nice looking turbo, Not sure if I want to paint the housing or not lol
No im just wondering,
anyways i got it retuned this morning again and because of timing and it was sort of pinging my tuner had to back the power off, now its on 255kw on 18 psi, i'll post the final tune tonite when i got a chance, im happy with the turbo either way.
V-band rear? yes
3.5" V-band
Very nice. I need one of these V-Band rears :woot:
That was my ceramic roller bearing highflow with a .60 comp housing :yes: and new externlly gated through turbine housing.
its pretty interesting seeing the 6boost's manifold has very long runners. any one can share some theory in doing that?
Equal length runners and merge collected so exhaust gas gets to the Turbo in equal/even bursts isn't it?
Pretty keen for this engine, really hope I can get the ext gate to work but think life won't be so bad if I have to go int gate I don't think
Need to trim the Turbo studs as one of them is fouling but other then that I'm very happy with how its looking :)
V-band rear? yes
3.5" V-band
Prob just me or the photo but v band doesn't look 3.5".
Plus I thought Stao told me once he could only do 3" max.
Hi Stao,
Long time no speak! As you already know, I'm currently running a top-mount Garrett GTX3076R but looking to return the car to stock-ish to sell and was wondering what the boost response is for the hi-flowed R33 standard turbo and the hi-flowed R34 turbo like compared to the stock R33 turbo.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
