Its been a while since this turbocharger has been developed is any one with a SR20det interested of trailing? The evaluation price on it is $750, and I will refund $100 once receiving your dyno reading so it will cost only $650. I would prefer a SR20det with injectors, pon cams other supporting mods in Melbourne. PM if interested
I want a sexy comp cover like that :P
Looks great Stao
BTW, the oil feed fitting that came with my turbo doesnt appear to fit in the block? its to small :S
Cheers. The one on the block is a M12x1.25 fitting and the one on turbo is M10x1.25. The straight hose tail goes to the block and the 90 degree end goes to the turbo. are both fittings you've got exactly the same?
Quick questions thou, a friend of mine is interest of introducing a stick on paint service, its a plastic alike material that sticks on cars body that you can peal them. Any one had their car stick on panted here?
Also I've got my Billet T67 CHRA machined and assembled today. will be doing comp and turbine housing tomorrow and there will be a little bit of a challenge as the the back plate adapting those two don't exist. Garrett patterned .70 housing uses pressure clamps while Greddy uses a large C clip. So it will has to be either C clipped and bolted or double clipped.
Yeah stao I think I got 2 fittings the same, one for the block looks about m8 or so thread to a -4 (?) Size fitting on the other side. Not a big deal if I know sizes
Your referring to vinyl wrap. It's quite common here in Sydney, lots of high end cars like C63, R35 etc are running around in Matte Black.
Looks pretty good. How much does your friend charge?
Plasti Dip
I looked into getting mine done a few months back.
In the states they use it a lot because its really cheap to buy a can is like $7
But to get it here once all the shipping is paid etc it turns out more like $30 a can.
I couldnt see him making any money if he is charging prices like that.
A company here already sells the stuff over priced IMO
Is that td05 or td06 billet compressor ?
That is a 25G compressor wheel and a .70 comp housing, turbine is SL2 TD06
Yes vinyl wrap is the one. I'm getting some photos send over today will post up. They comes in mat black, white, grey, red, clear and other colours. Costing wise at moment be looking at $850 for the whole car, will take about a full week to complete.
Customer's resulted based on a PU high flow, Rb25det VCT not enabled on pump 98 and E85
Stao out of curiosity what are the twin trust/greddy T517z 10cm turbos for rb26 gtr rated at (hp) ?
I would say about 450HP each turbo, in a twin setup with all supporting mods the 2nd turbo usually add in 70% of its full efficiency, how ever there are too many variances.
Further update on the T67. Finally got the back plate made and comp housing profiled. came up pretty nice:
Dame Trent's not coming back till Mid Jan. Got so many drawings made before xmas comes
Is this turbo a td05 or td06 and what is expected rwkw and it's billet wheeled right
I current have a kando td05 non billet and making 264rwkw e85 24psi dropping to 21 psi depends if it will make much more
That is very little power for alot of boost with E85.
I've made 2x versions of T518 turbos.
the one on photo is a TD05 with 18G billet comp wheel, I think it will probably do a maximum of 250rwkws on pump 98 with cams far as the turbine wheel and housing concern. I only made one, it was originally for GTScotT's SR20det but he's got a better turbo on it at this stage.
The other one was made using TD06SL2 turbine with 20G billet comp wheel since the 10CM external gated version was successful.
Hey Stao I installed my ATR43G3 last night. Had to modify the actuator bracket to make it fit but all ended up working. Just wondering what pressure the actuator is set to open at because currently I am only getting 11psi at full noise, all by about 4300rpm. Granted it hasn't been tuned yet, just wondering if this is normal or not.
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
