Stao what are the changes to these new SS1 and SS1.5 compared to my current SS1PU?
Can you please confirm sizes. Feel free to PM if its better.
SS1 is in 60mm, SS1.5 is in 64mm, while SS1PU is in 71mm.
Both wheels has 3mms in tip extension, customized hub.
The 60mm wheel has the equivalent blade size as the current 71mm cast wheel, and I've added couple degrees crop to the top so it won't be maxing out so early working with a Rb25det. This wheel should be excellent for people targeting 200~240rwkws on stock camed Rb20det/SR20dets.
The 64mm is a smaller version of the 71mm, how ever there isn't a lot of difference to the inducing and exducing area as most of that diameter has been taken out form the center hub, it does have very sharp throttle response, probably won't have as much top end, hopping to see bit more areas under the curve.
Went to a quite spot today and spent some time modifying the top left corner of my map as its caused some issues since dialling my cams in. I then added a bit of fuel across the entire map so I could open it up.
It used to hit 10psi at 3550, 14psi at 3800 and 17 at 3900
Today visually using rpm on controller and gauge I saw 14psi at 3500 and 17 at 3700. My controller is at 17 currently so it might have built more if it wasn't already tapering off.
Stao's 98 result on stock mani was 14 @ 3450 and 17 @ 3550 so I'm right there with him now. Just waiting on exhaust to be built and for me to make a cold air intake before retuning :)
Edit: oh and for me to wire up the water/meth controller
Edited by t_revz
Just thought I'd post to say that I got my car tuned by Toshi today and my god, the ATR43G3 is an amazing turbo. The response and power is great and I'm only on 16psi. Only did a road tune so I dont have power figures but I'm satisfied.
When I get it on the dyno I'll throw up a print out
Thanks for the feed back. And Happy new year to every one, Best wishes and more power cranking.
in photo is our OP6 high flow using SS2 CHRA:
Balanced using our brand new Dynamic turbo balancing machine with VSR cradle.
Stao I've been meaning to ask, what CHRA do you normally use in your 2IU highflows?
Also, my SS1PU SR is booked for its tune on the 15th. Hopefully a healthy result coming soon.
Thanks Stao, thats pretty cool info :)
Might try get a friend to consider one. I have had a lot of other people tell me the 2IU highflows you make work REALLY well. Testament to your work. I was just curious about the specs.
Yes can be done. Can also balance RC plan rotors, and remote control car wheels. lol
Further update, this is relation to current bearing setup. I'm trailing couple of high tensile steel ball bearings, as well as few different types of brass bearings that I've made earlier. Will upload result once done.
Nice looking BB cartridges Stao. Do you expect the BB's to make a huge difference? I've used bush and BB turbos before, but never seen back to back comparo of same turbo from same maker, so I'm very interested to see it.
Doesn't make much differences on the dyno. but in road driving there is a small difference in throttle response. how ever I'm pretty concert with the life span with those bearing specially when they are working in a hot environment with high speed and heavy thrust load.
In the bush bearing setup the centripetal and thrust support is the oil pressure supported by oil pump. So the bearings don't necessarily worn unless the pump fails or the oil has hard objects. I'm trying to get the same throttle response as the roller bearing through modifying oil galleries on the bearings and bore.
Can be done. Result in page 320. How ever only for evaluation at this stage.
Trent is Finally back, should have results for all 3 new turbochargers by weekend.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
