I would be interested to see inside the bore, and perhaps the plugs tips if they are still there. I too noticed the dint in the backing shield, dare I say Det damage? It looks like it's been blasted by hot metal particles.
Can a turbo perform better on a dyno than on the road?Like could two turbos that makes 250rwkw with the similar power curve get totally different results on the road.
I think what's happening is we are making the power but have a lot of lag between gears. On a dyno you're loading it up in 4th,so you don't see the difference between gears, but at the strip it makes a huge difference.
Now that I have the gopro hooked up I might test this and record the time to build boost back up.
I was completely oblivious until Stao rang me about it. The plugs were fine, the motor doesnt miss a beat and I havent seen any oil being burnt.
Unless some of my valves or pistons are missing chunks and somehow continue to run, i was thinking maybe some slag or something has come away from within my exhaust manifold and caused this.
The launch control probably doesnt do the turbine any favours either. :whistling:
Wait I thought this was stock manifold, what manifold is it for slat to let go?
I ask because ive seen a known brand manifold do this to a kando recently.
I met you at a trackday a while back.
Wasnt yours the car with the bolt-ons from another car (turbo, intake manifold, injectors etc etc) as well as the ECU. But the ecu was tuned for those mods of the bolt ons in the other car and you hadnt bothered to get it tuned again to your car, you just hooked it and and went from there.?
If so then some decent DET might have been occurring methinks...
Sorry you have me confused for someone else. I have an ATR43G3, standard plenum, nismo 550's and ViPec ECU.
I don't know about 115mph, but 106mph is way low for ~250wkw. Quite an odd pattern forming!
Thats stagea kw for mph..
I'm a bit lost, but most of the cars that have run the drags so far , are the ones that had problems on the dyno
anyway i thought, so i don't see a clear picture yet, Stao should go
cheers
darren
Edited by jet_r31
Was going to say that - my Prelude needed around 130kw to pull 96-98mph trap speeds and weighed ~1330kg as raced, must be an ultra low reading dyno to do 97+ with a "130kw" 300ZX.
I'd hope for over 98mph with 200kw in an R33 too, though.
That's what the dyno read and that's what i'm going off. I'd rather have the low reading dyno number and a good trap speed than the other way around.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
