thats a crazy result.. I like the way the torque stacks and fades off. I'd probably want that exact result for myself if I had an R33.
Is the CHRA in that SS2 core any different to the normal SS2?
22psi on e85 and shinnnnnnnnnning Dou dou dou dou
I will upload all the papers when I get a computer tonight. Doing it with my phone and it sucks.
Here is the dyno reading:
Boost:
Super responsive. Makes That about the same response as the SS1PU. Makes 17psi by 3500RPMs and about 100kws by 3000.
I will upload the videos shortly.
Video footage from today.
Surprisingly after multiple runs, the turbine housing or manifold did not turn red or overly heated. I guess this is the highest no. that a highflowed r33 turbocharger in factory housings has ever archived. This evaluation is pretty successful.
It how ever do cost $200 more then factory high flow option, for the extra work required on modifying standard turbine housing, as well as the high pressure actuator and SS2 billet compressor wheel.
I believe it is good for some where around the 280rwkws when used on stock manifold, internally gated on pump 98 fuel with good supporting mods and tune.
Yes the ATR43SS1 result of it on a Rb20det is on our site. SS1 billet version is updated version with better response. How ever I don't have a result of it based on a Rb25det.
Op6 should net around 370rwkws mark in this combination. I think I can get it close to 400rwkws with a different set of compressor profile. How ever it will be much laggier.
By the way, the SS2.5 is a CHRA made only for RB high flows, specially the 21U R33 housings. Won't be great used in normal housings.
I can also build the SS2.5 using the latest G3 comp wheel. Which will not add any costs to the standard profile while producing identical amount of power.
Standard high flow can get you a very responsive 250rwkws, while the SS2.5 or G3.5 can make more power will be laggy in the op6 rear housing.
I can do a special deal on the evaluation price of the G3.5. PM for further details.
Stao, that highflow is redonkulous.
What would that in an OP6 housing cost?
Every time I settle on a plan you go and do something that throws a spanner in the works....
I will do a special deal at $1160 including oil line. it might not be as responsive in the OP6 rear, how ever that should be reaching close to 370rwkws mark once setup on a proper manifold and gate.
Also releasing one more profile for the 21U turbine housing is the G3.5 This turbocharger is also a specific high flow built chra. it should produce bit more then the SS2.5. Hopefully be seeing towards 350rwkws mark. Its been pretty responsive using the 21U turbine housing.
Few other news is that I've managed to source some R33 copy turbine housings. That will help saving lot of costs building them here. I will pass on the savings and work out a cheaper alternative to high flows very soon.
  • Like 1
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
