feel free to bang through your map and i will have a look over it if your still chasing neddies.
This....... Is AWESOME! :yes:
sounds good Hanaldo, well done on the fault finding..always a massive pain in the ass...
cheers
darren
+1
Also good to hear that some of the drag results being off par for the dyno figures are now explainable, ideal result really! See, us folks who are saying things to the effect of "the strip results don't match the dyno results, something isn't right" aren't being haters at all - it is merely pointing out that one way or another there should be more performance to be had and something probably needs to be sorted.
Cheers for updating the thread with progress - that is what really helps these threads be genuinely informative, and nice work!
  • Like 1
^thats right, and dynoes can all read different across the board whereas mph is going to be a more controllable factor.
Ive been through the whole leak thing, power curve looks good on a dyno, laggier on the road than it should be and mph way, way down before scenario(like 6mph)
myself..it sucks a cock and its a prick to find
My brother had the same, 2 small cooler split hoses on a GT30 setup, fixed them and it made 10rwkw per hose..so 20rwkw..lol and then the kw per psi of boost added after came good aswell, whereas before that it was just leaking more with more boost and adding it made it worse
So many of us here have been through it before..and im keen as to see how you go now!
cheers
darren
Nice one Hanaldo, hope it goes well next tune! I'm having my own boost leak problems now and don't have the air compressor setup to easily find it either, it's a bitch.
Yeh tuners here don't seem to even know what that is :/
Nick, I bought my 2hp/24L air compressor, fitted air hose, tyre inflator, and dust blow gun all for $80. And my end cap I made up for about $2. Highly recommend, it's sooo easy to find leaks.
Ok, so I'm in the process of degreeing my cams, but I don't understand the Tomei cam spec card. Would somebody be able to take a look at the cam specs card on the Tomei website for the R34 Type B cams and help me out?
I THINK the specs card is showing crank degrees rather than cam degrees, so I want the cam angle to be 115 degrees BTDC, correct?
Sorry Martin, wish I could help with the cams..
Stao do you think that housing will be as accurately made as an original TS housing? Especially the shape and sizing of the two scrolls towards the nozzle area.
Yep thanks Trev, confirmed what I later worked out :D just finished the exhaust cam. It was 4.6 degrees advanced. Have now set it to spot on 115 degrees BTDC.
Now to do the intake... This is gonna be fun :glare: took about an hour and a half of dizzily trying to rotate the cam gear by 0.5 of a crank degree, and that's with being able to adjust the gear from the front. This intake gear is gonna be tedious if it's out :/
im guessing you cant access all the bolts easily? maybe undo them all and leave them finger tight then lock it with 1 or 2 of the bolts, remove the gear to lock them all then re-install and check with degree wheel again.
Nice to know you have made headway.. 4.6 degrees on the exhaust is massive.
Well the trouble with the intake gear is (I assume) we need to take the whole thing off and apart to adjust it. Which means taking the degree wheel, tensioner and timing belt off. Then adjusting it, then refitting it all and trying again.
Unless someone can point out an easier way, I haven't done it before. Trev?
And Yeh, I'm very surprised how far out it was. I don't understand how it could be so far out... Only the head has been decked when it was reconditioned, and there is no way it was decked enough to throw the timing out 4.6 degrees. So my only guess is that is how far out the camshaft was from its intended specs?
Wow. The intake cam is 7.8 degrees advanced. I've triple checked the equipment, I've triple checked the measurements. Its all correct, it's not an error from what I can see. But that is way out...
Yes, we shall see! These cam timing numbers give me confidence... Have been forced to stop until Monday though, don't have a 10mm allen key to take the VCT gear off. So I have until then to make sure these numbers are all spot on and find out how exactly to adjust the VCT gear.
should write up a tutorial
if yours are that far out then others may benefit too
7.8 degrees... That is insane.
its been a while since I fiddled with an RB but can't you take off the back plate which goes between the rocker covers and the gears which will give you access to the back of the intake gear? Just working off memory so feel free to tell me I'm way off.
Sounds like you have big news to come :-)
I just backed timing belt tension off a bit and rotate crank a smidge to slip the pulley off so balancer etc never had to come off for each adjustment. Think I got it in 3 adjustments.
I'd have to look yours up but on non neo standard exh is 117 and poncam is 115 so automatically there is 2 degrees. Maybe yours is a bigger difference. 7.8 degrees on intake is a whole tooth out :/
Are you checking at max lift or picking 2 measurements either side of max lift (ie .5mm before and after max lift and finding the centre mark) ?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
