This is recent and yet interesting result sent in from a customer running a SS2 turbocharger with a R34 GTT Auto. It was used as a bolton replacement internally gated.
It has:
Blitz front mount return flow cooler
1000 cc injectors
255 pump JJr front pipe
Z32 AFM
Nistune
E85
Stock Auto with a transmission oil cooler
300rwkws @ 17psi of boost:
So car is booked in for a tune on thurs. previous tune was 345rwhp on 17psi with the now outdated ATR43G3 type A internal gate. Now has the later version with the updated comp housing i think, ball bearing cartridge and type B housing (thanks to Stao for uprading me for free!). Tuner has recommended to block off the BOV after i asked if the stock one could hold 20psi. Cant wait, havent boosted for about 3-4 months :(
  • Like 1
Its extremely important remembering to preload the actuator as the tuner's tuning. keep on preloading if are seeing boost tapering off before the desired level. It might be 5mms or could be 15mms, the more you load it the higher up top boost level it will hold, more boost makes more power.
4-5mm preloaded on it at the moment. I've never had the boost tapering off issue, infact its been the opposite with mine, pressure increasing towards redline.
Good luck Landscribble, hope the kw's flow freely :)
I've got an g3 type A, so it's definitely possible to get a result.
Thanks, i hope aswell but now im not really fussed if it doesnt match Stao's results, aslong as i can drive the thing im happy. I know the turbo's can make the power having made 279rwkw previously by a different tuner, i chose to go the type B for a little faster response.
I preloaded mine Around 8 or so mms, With a 14 pound spring, it boosts to 23 psi, tapering down to ~20psi now.
I find it very wierd its even getting to 23 psi, ( boost controller is Off )
Does this mean to much preload?
Ah you could have bought my SS2 instead.....comes with R33 coupe :whistling:
I think its a good boost level. Usually the boost curve starts to spike then drop. with more preload it starts to hold, and if over loaded the boost starts to creep. Thats I usually adjust mine with internal gate.
Ill prob remove the controller all together then, as it might still be affecting it even plugged plumbed in.
It does feel alot more consistent when boosting now.
If youve got it able to hold 20 off the spring (peaking 23) that is really good.
Provided your car is tuned at that level I give you the big thumbs up.
Just watch it when the weather changes as that can make it jump :)
Car is tuned for 22 pound tapering down to 14-16 pound.
So....not really tuned now..
I will be getting a new low manifold/external gate soon so im hoping to hold of on a new tune until i get those.
Question: How do Dyno Tuners measure Boost ( pressure )?
Might be a dumb question, but just want to know how they measure.
Edited by jay-rod
hose in plenum
After having the car at a workshop for 8 business days and not tuned, and it getting put of , i went and drove it home on the nistune basemap.
Cars now booked in next thursday arvo to get tuned by Matt from nistune on a mainline dyno(apparently the dyno of truth so the young kiddies tell me..lol)
Going to tune it on 98 and wmi disconnected first and get the best out of it , then connect it up and go from there..
cheers
darren
Edited by jet_r31
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
