i guessing the ss4 comp wheel is 62mm ish, have you backed to back them
on xr6turbos. Be a better match no doubt to the old staple diet of fitting
the t04z wheel to them before the gtx3582 came out. Wonder what a
ss4 would be like with a p- trim sized rear?
cheers
darren
ss4s compressor is in 85mms compare to the usual 82mms. I will be using that with a .82 turbine. That should be plenty for a 2.5l with a large external gate.
Yes and I think I can make it street drive able too.
LOL that would be hilarious. Something tells me it wouldn't last long, and "drivable" would need to be very loosely defined :D
LOL that would be hilarious. Something tells me "it" wouldn't last long, and "drivable" would need to be very loosely defined :D
It: would be every thing apart from the turbocharger.
Pretty sure I can make it work. So interested to give it a shot? :D
have a problem...my external gate is quiet sometimes..car goes lame..other times gate is loud(like it should be)..
car goes pretty hard for what it is...when gate is loud, guessing its a boost leak..a random one. As i never drive it,and 99 percentof the time have the kids
in car, its taken me 5-6 weeks to work out
what is happening, thought my ears and bum dyno where broken.
I actually drove it all last weekend,by myself for once it was wet road was damp..noisy gate..no traction in first and quarter way through second(auto).did this
about 4 times , then went to a mates .first gear ,no noise
no wheelspin in first and gutless as f**k and then it twigged..i am not dreaming
(and no i don't usually drive like this, i actually hated giving the poor thing a hard time, but i wanted to establish if i was infact dreaming or not)
boost leak..random..stock bov's failing perhaps?, anyone had this problem before..might explain a few things like the turbo woudn't make
any power over 19psi on dyno..any more and it pumped hot air , had me puzzled at the time , and the ex gate was quiet then aswell from memory..actually mate has identical setup and gate and was quiet at the time compared to his.....having never driven it before i thought it was the way it was, but no its been louder after..
actually few other things have happened aswell, now i think of it..hmmm, like boost went up WAY higher than what the ebc was setup for on dyno'
which was 19psi. I originally though it was the ebc as it was broken and repaired by my brother and i was going to test a few things this weekend.
i was just surfing sau, and noticed someone has similiar problem, and quiet ex gate and they hadn't hooked up there blow of valve
line so it stayed open..which leads me to look there tomoz , maybe its faulty???
cheers
darren
Edited by jet_r31
when ive had broken diaphragm, its broken...doesn't fix itself,won't it overboost?..its underboosting..
its a turbodumb 38mm with 19psi spring
Car has been doing this from the beginning, its random Stao, sometimes loud, sometimes quiet, feels fast, feels slow
i thought it was the surroundings and the noise sometimes didn't echoe, and thought i was just getting used to power, but no its not that, its gutless
when its quiet
mate had same problem with gcg hi-flow, 215rwkw and shit boost control, put a turbosmart replacement blow off valve on and made 244rwkw
he told me to fit one when i built it, but searching on here, everyone said they are generally fine so i left it
I'll check gate on weekend aswell
cheers
darren
Turbo would probably find a way to die just so it doesn't have to put up with being on such a pathetically depressing setup :P but yeah, every part of the engine and drivetrain other than the turbo would shit itself in spectacular fashion methinks! hahaha
On a semi-serious note, later this year I'll look into getting rid of the van and replacing it with something like a Golf R....depending on warranty etc (if I buy new or used), I might look into modifying it for ~250awkw or maybe a touch more, and optimum response...who knows where that'll lead me :P
Hooo The VW Golf R. Remember to buy the one with a Wet box. Don't go any where near the DSG dry box stuff. They are horribly bad. The Chinese government made VW to do a huge recall on all their cars with DSG dry boxes, and many of my VW clients and tuners I build turbos for have reported this problem.
They also run direct injection, you can run them on Audi R4 mechanical fuel pumps and injectors. There isn't much ecu options apart from few people that makes fixed data flash tunes. I think Link G4 recently made some thing for older Golf models, but doesn't work with current models.
VW modification cost lots of $$$$ and the end results are no where near to a stock Rb25det.
If u got the cash Buy my test rig :yes: its already been modified and all you have to do is drive it. I need garage room for a GTR.
The box issue is only in the 7 speeds yeah?
7 speed DSG, there are also reports from the wet boxes failure, how ever the problem isn't as severe. Apparently they stuck in gears, rapid shifting gears, case sudden lose of power or sudden acceleration. VW declear a problem with the Auto controller software, that causes the premature wear of its clutch plates and fly wheel. how ever the issues are yet to be rectified. And that is on a factory tuned vehicle. Seems to be in certain VW from 2009 ~ current.
Ooh... Missus has the 2012 GTi and thought she was in the clear after the recalls... Maybe not! Anyway, not derailing your thread............... Again :P
I don't understand this "wet/dry" box dealio, but the Golf R only comes with a 6 spd DSG I believe.....either way, if I go back to a performance car of any kind, I don't think I could go back to a Skyline lol. As much as I LOVED driving that car, the endless f**king problems it had along with the money it drained just maintaining it to the piss poor standard it was at really drained me emotionally >.<
I'd only get something that literally didn't need another cent put into it. Full engine build, reconditioned gearbox, looks great, zero problems. Unfortunately for the money I'd need to fork out for the right Skyline, I could get something much "better quality" :(
Plus if I went back to a Skyline, it would probably have to be a GT-R hahaha
Actually after modifying S14, 180sx, 300ZX, Soarer and R32. Modding R33 is like walking into heaven, this is probably the easiest car to modify, with plenty of parts available, and getting power out of the Rb25det is so easy. Compare to the rest the R33 made the most amount of power with the least amount of money spent.
Definitely, but after the headaches mine put me through it'd wanna be fully engineered and ACT RWC provided before I'd even entertain the idea of getting another one haha... I do miss 2nd gear ice skating in the dry though :(
Some updates:
This is the SS1PU Alfa version.
I will make Alfa version stand for our most advanced turbo systems that delivers the ultimate power and response. VNT, BB, CBB, Billet wheels, customized bell shape inner profiles and etc will all be parts of this project.
As in the turbocharger above: I have trimmed down a older SS2 comp wheel to produce around the 320rwkws mark since the turbine end is only capable of flowing up to 322rwkws. Which I rather turn the additional load into response. I want this to be the most responsive 320rwkws any thing can ever produce.
Some updates:
does it come with a HKS badge?
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
