Needs 'Hypergear ALFA series' cnc'd into the front housing, on the built plate area. :)
Can you do the above to an M35 turbo for me Tao? Is that 320kw on e85 or 98?
If it can get up to about 340rwkws then that would be sweet. Means about 300rwkws on pump 98.
I drove it on low gears light throttle around the block, it felt like a stock turbo more then any thing else. Be interested to see what the dyno says in few weeks time. If works well this would be an excellent turbo for Rb20det and SR20det engines.
Advanced Lag Fighting Abilities?
:whistling:
Yes you are right. :D Its actually from Alfa Romeo . Alpha sounds too american. Lets stick with American wording for now.
To produce this it has to out perform the SS2 Alpha version which I think that is extremely good. Will post result after Trents get back from UK.
Just clear up some confusion as proportion of people don't understand how the alpha turbocharger is any different to traditional turbochargers.
If a traditional turbocharger is built for 600HP it will be, drive and act like a 600HP turbocharger in all rev ranges.
At same HP, the Alpha turbocharges, drives as a 400HP turbo from 0~4000RPMs, 500HP turbo from 4000~5000RPM, 600HP turbo from 5000~7000RPM. So it will always feels like a baby turbo to drive while produces decent top end.
At any given freedom of variable nozzles angle, the turbocharger is only capable of producing a proportion of it full HP capacity. For example if nozzles are fixed at 10 degrees a 600HP turbocharger will only produce 300HP maximum, 30 degrees at 450HP, 45 degrees at 500HP, and 50 degrees at 600HP.
When controlled by an actuator with preset actuation levels, on given boost, this turbocharger will expand it self from a 300HP turbo to a 600HP turbo as engine reves out, then contract to a 300HP turbocharger off acceleration. It repeats this process throughout the whole driving course.
Most of our budget went into developing and research for newer innovations. This is a giant step forward for modern performance turbochargers.
Updates of some unusual turbocharger. The Schwitzer turbo out of a early model Toyota land cruiser diesel.
Turning that into our Billet TD05H18.5G is a total workout in ingenuity. Here it is:
Expected to gain about 15% more torque without adding much lag.
An old Schwitzer hey. I rebuilt an excavator engine with a Schwitzer turbo on it a few years ago. That turbo was a bit bigger however, about 40kg
Just remember how funny the name was when you say it with some sort of European accent :P
Not all... :ph34r:
No, Stao was right when he said "all". A 600HP turbo will feel like crap at 2500rpm. That's what he meant. His 600HP alpha turbo will feel like a 400HP turbo at 2500rpm, but will be capable of also doing 600HP.
Mine has plenty down low! Of course you can feel its not a stock turbo and you know its big but its not a lag monster by any means! The dyno sheet doesnt do it justice... I just think that general statement is wrong!
No......yours does feel like a 600HP turbo down low. Just because it is Stao's special recipe and is actually quite good down low doesn't mean it can't be better. If you add his Extra Special Recipe © to it, it will be even more good down low. That's what he was saying.
I mean, lets' be fair......I'm not rubbishing the turbo you have, because I know full well that it is a good thing. The point is that it must spool a bit slower than the stocker, and the stocker is a 400HP turbo. An old, crappy 400HP turbo, but let's ignore that aspect of it. Stao's statement was,"Add VNT to your big turbo, get stock turbo response at low rpm, add big grin to face."
Edited by GTSBoy
Oh, didnt realise you had driven my car :) My bad...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
