Stao quick question. Its really pointless but thought I'd ask.
The green XR6T known as toxic has a bent exhaust wheel fin. It produces a sound like a supercharger.
Video here.
Guy claims it doesn't affect performance. Can you do this on one of your turbo's and achieve this sound or was his by sheer luck lol. I don't care what anyone says but it sounds awesome.
LoL no. I would pull it part and replace the exhaust wheel. Unfortunately Garrett no long sale rebuilding parts for their own turbos, so it needs to be fully overhauled. I would not buy that car the way it is.
Some news for SR20det lovers
This is the latest ATR28SS1.5 It is engineered to peek 260rwkws on pump 98 with supporting mods while has a stock T28's response.
Cool!!
Any dyno graphs?
For a fairly stock setup, when does full boost come on with this turbo?
Currently only have results from it on a Rb25det with larger turbine housing. That made 298rwkws on 21psi with full boost by 3600RPMs.
SR20det using a smaller .64 rear should behave very similarly. But no SR20det result on this turbocharger so far. This customer should have a result for me very soon.
Bargain!
So let me get this straight. Its smaller than the the ss1pu, makes more power and is more responsive on an SR20
Have i understood this correct?
Cheers
Hey Morgan,
It's smaller than the SS1PU and will make less power in total. Stao is referring to his E85 results, where his SS1PU E85 result was over 320kw IIRC.
I have forgotten to PM you in some time so are due for a catch :) PM me if you need me to clarify.
Hey Morgan,
Hey Man hows it been?
I'm a little confused bro, stao's post above states 260rwkw on 98 not e85. I want as much response as possible and it seems that the ss1.5 will deliver the same power earlier on than the ss1pu but the ss1pu will make more up top.
Sorry, I saw his response of 298 which is E85, missed the 260kw bit.
Remember these figures are based on his testing with the RB25, so while he knows it will have about 260kw worth of flow on 98 that is also compared to the SS1PU having nearly 280 worth of flow on 98.
Stao are the smaller SS wheels still based on the original high/low blade design or are all SS turbos now using the same straight blade design as the SS2?
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
